Hébergements Web - Comment rétablir l'accès à mon site sesamonestier.fr après l'installation de W3 Total Cache ?
Frage
Von
Ben Rvl
Erstellungsdatum 2024-12-30 09:25:39 in Hébergements Web
Hello everyone,
I am facing an issue with my website sesamonestier.fr, hosted on OVH servers. I installed WordPress, and everything was working fine until I added the W3 Total Cache plugin. Since then, my site has stopped loading, and I can no longer access either the WordPress admin panel or the configuration of my OVH services.
Do you have any solutions to fix this issue? Is it possible to disable this plugin through an alternative method or restore my site’s normal functionality?
Thank you in advance for your help. Please let me know if you need any additional information.
Best regards,
Ben
1 Antwort ( Latest reply on 2024-12-30 12:42:36 Von
fritz2cat 🇧🇪 🇪🇺
Hello,
You may want to browse into your FTP directory, do to the folder named wp-content, then plugins.
Rename the directory containing the offending plugin. It has the effect of disabling it.
