Je viens de prendre un forfait à 0,99€ et un numéro belge.
Je l'ai configuré sur Asterisk (FreePBX) pour l'utiliser avec les 3 téléphones qui sont dans ma maison + portier SIP. Néanmoins je constate dans les logs que le trunk est défini comme Unreachable régulièrement (une dizaine de fois par heure) et redevient Reachable qq secondes après.
Voici une partie des logs:
[2019-09-23 14:57:57] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (17ms / 300ms)
[2019-09-23 14:59:58] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 18
[2019-09-23 15:00:08] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (19ms / 300ms)
[2019-09-23 15:01:09] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 19
[2019-09-23 15:01:40] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (17ms / 300ms)
[2019-09-23 15:08:41] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 19
[2019-09-23 15:09:01] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:13:02] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 16
[2019-09-23 15:13:22] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:16:23] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 16
[2019-09-23 15:16:44] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (19ms / 300ms)
[2019-09-23 15:26:44] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 18
[2019-09-23 15:26:55] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (17ms / 300ms)
[2019-09-23 15:34:55] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 19
[2019-09-23 15:35:05] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (17ms / 300ms)
[2019-09-23 15:42:06] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 18
[2019-09-23 15:42:16] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:49:17] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 22
[2019-09-23 15:49:27] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:51:27] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 17
[2019-09-23 15:51:37] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:54:38] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 19
[2019-09-23 15:54:48] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:55:49] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 18
[2019-09-23 15:56:09] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
[2019-09-23 15:57:10] NOTICE[495] chan_sip.c: Peer 'OVH' is now UNREACHABLE! Last qualify: 18
[2019-09-23 15:57:20] NOTICE[495] chan_sip.c: Peer 'OVH' is now Reachable. (18ms / 300ms)
Aurais-je omis un paramètre ?
Voici la config du trunk
host=sip5.ovh.be
username=XXXXXXXXX
secret=XXXXXXXXX
type=peer
qualify=300
insecure=very
canreinvite=no
fromuser=XXXXXXXXX
Aussi, j'utilise FreePBX dans un docker sur un NAS Synology, pourrait-il que ce soit lié?
Merci pour votre aide! :)
Forfaits VoIP - OVH sur Asterisk: trunk Reachable - Unreachable, normal ou pas?
- Configuration SIP VOH avec une application SIP sur android
55329
12.09.2019 07:50
- Sip ovh sur android ?
54624
04.06.2017 19:32
- Un numéro injoignable et support ovh ne répond pas aux demandes
50435
25.04.2018 09:06
- VOIP + 4G BOX besoin d'aide
45634
17.03.2017 11:13
- Configuration Zoiper pour Android 8.1.0
44118
18.01.2019 19:01
- Paramétrage Serveur SIP et compte SIP sur Huawei E5186s-22a
43660
21.12.2017 09:47
- Téléphonie en Belgique
43344
09.12.2016 07:31
- Cisco 8851 reçu non configuré
39838
07.06.2018 08:53
- Ip interdite sur Téléphone Yealink W60P
39239
03.01.2019 18:21
- Ligne tel OVH configurée sur BBOX3 Proximus
33605
07.12.2021 07:51
