**Problème d'envoie des Emails à toute adresse @gmail.com.**
**ex :**
A partir de Outlook , je n'arrive plus à envoyé des Emails vers mes contacts @gmail.com
J'ai essayé à partir du Webmail de OVH, j'ai le même problème.
Message d'erreur :
This is the mail system at host mo557.mail-out.ovh.net.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
: host gmail-smtp-in.l.google.com[173.194.76.27]
said: 550-5.7.26 This mail is unauthenticated, which poses a security risk
to the 550-5.7.26 sender and Gmail users, and has been blocked. The sender
must 550-5.7.26 authenticate with at least one of SPF or DKIM. For this
message, 550-5.7.26 DKIM checks did not pass and SPF check for
[adntechnologies.be] did 550-5.7.26 not pass with ip: [46.105.34.168]. The
sender should visit 550-5.7.26
https://support.google.com/mail/answer/81126#authentication for 550 5.7.26
instructions on setting up authentication.
g9-20020adffc89000000b0030b5d203e89si5254916wrr.1008 - gsmtp (in reply to
end of DATA command)
E-mails et solutions Office - Problème d'envoie des Emails à toute adresse qui se termine pas @gmail.com
123425
03.01.2024 08:02
120777
24.06.2017 14:28
120656
13.08.2017 18:14
96654
23.11.2016 15:15
- Question sur antispam OVH
94677
17.03.2017 16:11
93384
07.08.2017 08:45
88780
30.11.2017 11:26
84758
15.11.2017 10:30
81610
05.04.2017 11:42
81473
12.03.2019 17:41
Voyez ma réponse au même problème identique au vôtre https://community.ovh.com/t/Probl%C3%A8me-envoi-mail-%C3%A0-une-adresse-gmailcom/58989
