Help transferring domain name to hosting
Hello, I’m posting this message because, despite consulting the OVH documentation, I can’t find the solution to my problem.
I had until last Friday a simple subscription for a domain name at OVH (so domain name + associated free hosting).
I ordered hosting, still with OVH, using the STARTER plan in order to have a database and a CMS.
My question is the following: how should I proceed so that my site attached to my domain name is hosted on the new hosting?
Thank you in advance for your answers.
Christophe
Hello @ChristopheN
It's very simple, just:
  • Retrieve the server's IP address in OVH Manager > Web Cloud > Hosting > YourDomain > General Information
  • Assign this IP address to the "A" record in OVH Manager > Web Cloud > Domain > YourDomain > DNS Zone
________________________________________________________________
Here's a short guide I wrote that could give you some clarity for a complete and clean installation of your site.
Guide – Understanding the Relationship Domain > DNS Zone > Hosting > Site Folder
See --> CMS - WordPress - OVH Installation Guide
Read and check your situation by following the paragraphs carefully: A to J applicable to all CMS
Feel free to give me feedback: positive or negative.
That's how I refine my guide.
If my answer is the solution, feel free to click the “Solution” button
Hello @Gaston and thank you for your quick response.
The problem is that the IP address is the same for the hosting I have with the domain name and the hosting I subscribed to in the STARTER plan... so I’m not really sure how to proceed...
Do you have any idea?
Thank you
Hello @ChristopheN
If your two hosting accounts are on the same cluster, they will share the same IP address. However, it is not possible to bind a domain name to two plans that are on the same cluster.
Here, it will therefore be necessary to permanently delete the free plan so that you can add your domain name to the multisite of your Starter plan.
It is important to note that this will completely delete the plan along with the content present on the hosting and the associated mailbox if it has been set up.
If needed, I invite you to back up these two items:
To proceed with the deletion of the free plan, I invite you to click this link: https://www.ovh.com/manager/dedicated/#/billing/autoRenew, using the small dots next to the "hosting" line, then the option "Delete hosting immediately".
You will then receive a confirmation email at your OVHcloud contact email address, which I invite you to confirm; the plan will then be suspended.
Warning, if you choose the "terminate" option on a plan, the plan will only be suspended on the service expiration date. You must explicitly request immediate deletion.
Once this is done, I invite you to return to support via a ticket, indicating your wish to accelerate the deletion process of this plan so I can delete it permanently.
Feel free to share the ticket number with me so I can handle it internally :wink:
Astérix
Hello @ChristopheN
Indeed, I had forgotten to mention that if the free hosting of the cluster and the hosting subscription you purchased share the same server address, it won’t work.
As @Asterix told you, you first need to delete the small free 100 MB domain attached to another domain, and then you can carry out the steps I outlined in my previous email.
Hello @Asterix and thank you for your response. Before proceeding with the deletion of the free offer, will it impact the 14 email addresses I have on Zimbra Mail?
Do you have an MX plan?
In principle, if all your email addresses are already in an MX plan, you shouldn’t experience any email address deletions.
I have an MXPLAN, but the addresses aren’t attached to it. They’re on Zimbra Mail...
Here I hand the floor over to the experts. :wink:
No! Deleting the Start100M plan will have no impact on the Zimbra offering.
:wink:
I have just submitted the cancellation request. Here is the ticket number to speed up the process
CS16918193
Thank you in advance,
I assigned it to myself and replied to your support request :wink:
Astérix
Thank you for your help!
All the best, Christophe
