Need help migrating from o2switch shared hosting to OVH VPS Plesk
Unsatisfied with the performance of o2switch shared hosting for a WordPress site, I ordered a 3‑VPS OVH under Plesk Web Pro.
The current site is hosted on cPanel.
I would have liked to use the Plesk Migrator extension but SSH access to o2switch is impossible directly via the IP address.
I tried using Plesk’s site‑import extension, but despite correct configuration, I get an error I can’t resolve.
I have tried different WordPress migration plugins: UpdraftPlus, Duplicator, and Migrate‑Guru. I get fatal errors each time.
Finally, the rsync and SQL‑dump solution worked best, but it ends with an error
AH01071: Got error 'PHP message: PHP Fatal error: Uncaught TypeError: ftp_pwd(): Argument #1 ($ftp) must be of type FTP\Connection, null given....
and I can’t solve it.
I’m desperate to achieve a clean migration of this WordPress site. If anyone has any leads, I would really appreciate them. Thanks!
Hello @laurent_ns
I invite you to read my guide below, especially paragraphs O11 and O12
https://www.wordetweb.com/word-et-web/WORDPRESS-guide-installation-de-WordPress-premier-domaine-chez-OVH-FR.htm#_O_-_WordPress
I have already tried the tools you suggested, but without success.
Hence my plan to perform the operations manually myself
Hey,
Since you have an O2SW instance, I think there should be a way to connect via SSH... maybe a hidden option in the panel?
Otherwise a slower option via SFTP :slight_smile:
Thank you for your feedback.
Before proceeding, I tried one last WordPress plugin, Vivid, which worked for me.
I was able to complete the migration with a few minor adjustments.
