Je suis totalement novice en informatique et mes courriels sont bloqués par les adresse gmail.
This is the mail system at host mo511.mail-out.ovh.net.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
: host gmail-smtp-in.l.google.com[74.125.71.27] said:
550-5.7.26 This mail has been blocked because the sender is
unauthenticated. 550-5.7.26 Gmail requires all senders to authenticate with
either SPF or DKIM. 550-5.7.26 550-5.7.26 Authentication results:
550-5.7.26 DKIM = did not pass 550-5.7.26 SPF [yildiz-avocat.fr] with ip:
[54.36.141.1] = did not pass 550-5.7.26 550-5.7.26 For instructions on
setting up authentication, go to 550 5.7.26
https://support.google.com/mail/answer/81126#authentication
y14-20020adffa4e000000b0033b3b99f700si699239wrr.10 - gsmtp (in reply to end
of DATA command)
Reporting-MTA: dns; mo511.mail-out.ovh.net
X-Postfix-Queue-ID: 4TWTFm5Wmqz1KmF
X-Postfix-Sender: rfc822; contact@yildiz-avocat.fr
Arrival-Date: Fri, 9 Feb 2024 09:34:20 +0000 (UTC)
Final-Recipient: rfc822; XXXX@gmail.com
Original-Recipient: rfc822;XXXX@gmail.com
Action: failed
Status: 5.7.26
Remote-MTA: dns; gmail-smtp-in.l.google.com
Diagnostic-Code: smtp; 550-5.7.26 This mail has been blocked because the sender
is unauthenticated. 550-5.7.26 Gmail requires all senders to authenticate
with either SPF or DKIM. 550-5.7.26 550-5.7.26 Authentication results:
Return-Path:
Received: from ex3.mail.ovh.net (unknown [10.108.54.205])
by mo511.mail-out.ovh.net (Postfix) with ESMTPS id 4TWTFm5Wmqz1KmF
for ; Fri, 9 Feb 2024 09:34:20 +0000 (UTC)
Received: from [192.168.1.26] (195.135.125.142) by DAG3EX1.indiv3.local
(172.16.2.5) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.1.2507.35; Fri, 9 Feb
2024 10:34:18 +0100
User-Agent: Microsoft-MacOutlook/16.66.22102801
Date: Fri, 9 Feb 2024 10:34:17 +0100
Subject: Re: XXXXX
To:
CC: Yildiz - AVOCAT
Message-ID:
Thread-Topic: XXXX
References: <002601da5b38$69d899f0$3d89cdd0$@gmail.com>
In-Reply-To: <002601da5b38$69d899f0$3d89cdd0$@gmail.com>
MIME-Version: 1.0
Content-Type: multipart/mixed; boundary="B_3790319658_17879143"
X-Originating-IP: [195.135.125.142]
X-ClientProxiedBy: CAS6.indiv3.local (172.16.1.6) To DAG3EX1.indiv3.local
(172.16.2.5)
X-Ovh-Tracer-Id: 17409790263554658018
X-VR-SPAMSTATE: OK
X-VR-SPAMSCORE: 0
X-VR-SPAMCAUSE: gggruggvucftvghtrhhoucdtuddrgedvledrtdeigddthecutefuodetggdotefrodftvfcurfhrohhfihhlvgemucfqggfjpdevjffgvefmvefgnecuuegrihhlohhuthemucehtddtnecunecujfgurhepfgffuffhvfevkfhfjgggtghisehmtdhmredtreejnecuhfhrohhmpegjihhlughiiicuqdcuteggqfevtefvuceotghonhhtrggttheshihilhguihiiqdgrvhhotggrthdrfhhrqeenucggtffrrghtthgvrhhnpeeggefhjedtteeukefggeeljeevleekieduudekvdejheeggfefveetjeeigfeikeenucffohhmrghinheprghvrghsthdrtghomhenucfkphepuddvjedrtddrtddruddpudelhedrudefhedruddvhedrudegvdenucevlhhushhtvghrufhiiigvpedtnecurfgrrhgrmhepihhnvghtpeduvdejrddtrddtrddupdhmrghilhhfrhhomhepoegtohhnthgrtghtseihihhlughiiidqrghvohgtrghtrdhfrheqpdhnsggprhgtphhtthhopedupdhrtghpthhtoheprgihrghrihdrlhgvghgrlhesghhmrghilhdrtghomhdpoffvtefjohhsthepmhhoheduuddpmhhouggvpehsmhhtphhouhht
Quelle est la manipulation à faire pour débloquer l'envoi des courriels vers des adresses GMAIL ?
Merci beaucoup.
Salli
1avocat.fravocat.fr
Vous avez mis vos serveurs DNS chez Wix et il faut supporter les conséquences de cette modification.
Chez Wix il vous manque votre enregistrement SPF.
Voyez mon article (environ à la 10è ligne)
https://blog.demees.net/cname-ovh-systemeio-shopify-heroku-odoo-wix-monsite/
Bonjour @SalliY,
Si le retour apporté par @Fritz2cat répond à votre demande, je vous invite à marquer ce dernier comme solution.
^FabL
