Connection timeout constants
Version OTB en 0.6-33
Problème rencontré
J'ai sans arrêt des timeouts dans les logs rendant impossible ma connexion en OPEN VPN sur mon site.
2022-12-08 14:41:29 TCP/UDP: Preserving recently used remote address: [AF_INET]XXX.YYY.ZZZZ.WWW:0000
2022-12-08 14:41:29 UDPv4 link local (bound): [AF_INET][undef]:0000
2022-12-08 14:41:29 UDPv4 link remote: [AF_INET]XXX.YYY.ZZZZ.WWW:0000
2022-12-08 14:42:29 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
2022-12-08 14:42:29 TLS Error: TLS handshake failed
2022-12-08 14:42:29 SIGUSR1[soft,tls-error] received, process restarting
Aujourd'hui encore connexion Impossible de 14h20 a 14h47.
Si quelqu'un peut regarder ce qui se passe pour correction ?
Thu Dec 8 14:27:26 2022 user.notice otb-qos: checking QoS
Thu Dec 8 14:27:26 2022 daemon.info logread[15912]: failed to send log data to 5.135.240.117:22837 via udp
Thu Dec 8 14:27:27 2022 daemon.info logread[15912]: Logread connected to 5.135.240.117:22837
Thu Dec 8 14:27:27 2022 daemon.err otb-tracker[16942]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:27:27 2022 user.notice otb-qos: /0 QoS applied. Need to restart
Thu Dec 8 14:27:27 2022 user.notice otb-qos: restarting QoS
Thu Dec 8 14:27:27 2022 user.notice otb-qos: stopping QoS
Thu Dec 8 14:27:27 2022 user.notice otb-qos: starting QoS
Thu Dec 8 14:27:38 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:27:38 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:27:38 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:27:40 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:27:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:27:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:27:43 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:27:44 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:27:45 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:17 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:18 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:19 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:20 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:21 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:22 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:54 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:55 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:56 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:28:57 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:58 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:28:59 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:25 2022 daemon.err otb-tracker[16940]: curl: (28) Operation timed out after 1000 milliseconds with 0 bytes received
Thu Dec 8 14:29:33 2022 daemon.err otb-tracker[16939]: curl: (7) Failed to connect to ifconfig.ovh port 80: Operation timed out
Thu Dec 8 14:29:34 2022 daemon.err otb-tracker[16939]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:34 2022 daemon.err ss-redir[26335]: 2022-12-08 14:29:34 ERROR: remote recv: Connection reset by peer
Thu Dec 8 14:29:34 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:35 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:36 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:37 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:38 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:29:39 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:13 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:14 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:15 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:16 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:17 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:18 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:55 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:30:56 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:57 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:58 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:30:59 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:00 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:05 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 5000 milliseconds with 0 bytes received
Thu Dec 8 14:31:35 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:31:35 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:31:35 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:31:37 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:38 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:39 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:40 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:31:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:16 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:17 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:18 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:18 2022 daemon.err ss-redir[26335]: 2022-12-08 14:32:18 ERROR: send: Connection reset by peer
Thu Dec 8 14:32:19 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:20 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:21 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:26 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 5000 milliseconds with 0 bytes received
Thu Dec 8 14:32:56 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:32:56 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:32:56 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:32:58 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:32:59 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:33:00 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:33:01 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:33:02 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:33:03 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:33:39 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:33:40 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:33:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:33:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:33:43 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:33:44 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:34:18 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:34:19 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:34:20 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:34:21 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:34:22 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:34:23 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:34:27 2022 daemon.err otb-tracker[16940]: curl: (28) Operation timed out after 1000 milliseconds with 0 bytes received
Thu Dec 8 14:34:28 2022 daemon.err otb-tracker[16940]: curl: (28) Operation timed out after 1000 milliseconds with 0 bytes received
Thu Dec 8 14:34:31 2022 daemon.err otb-tracker[16940]: curl: (28) Operation timed out after 1000 milliseconds with 0 bytes received
Thu Dec 8 14:35:00 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:35:01 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:35:02 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:35:03 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:35:04 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:35:05 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:35:40 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:35:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:35:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:35:43 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:35:44 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:35:45 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:36:21 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:36:22 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:36:23 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:36:24 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:36:25 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:36:26 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:37:02 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:03 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:04 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:05 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:37:06 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:07 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:43 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:44 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:45 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:37:46 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:20 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:21 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:22 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:23 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:24 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:25 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:38:30 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 5001 milliseconds with 0 out of 0 bytes received
Thu Dec 8 14:39:00 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:39:00 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:39:00 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:39:03 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:04 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:39:05 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:06 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:07 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:08 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:43 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:44 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:45 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:46 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:39:51 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 5000 milliseconds with 0 bytes received
Thu Dec 8 14:40:21 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:40:21 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:40:21 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:40:23 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:40:24 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:40:25 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:40:26 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:40:27 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:40:28 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:40:33 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 5000 milliseconds with 0 bytes received
Thu Dec 8 14:41:03 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:41:03 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:41:03 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:41:05 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:06 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:07 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:08 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:09 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:10 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:15 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 5001 milliseconds with 0 out of 0 bytes received
Thu Dec 8 14:41:45 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:41:45 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:41:45 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:41:47 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:48 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:49 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:50 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:51 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:41:52 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:42:27 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:42:28 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:42:29 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:42:30 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:42:31 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:42:32 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:06 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:43:07 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:43:08 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:43:09 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:43:10 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:43:11 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:43:45 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:47 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:48 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:49 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:50 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:51 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:43:59 2022 daemon.err ss-redir[26335]: 2022-12-08 14:43:59 ERROR: server recv: Operation timed out
Thu Dec 8 14:44:24 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:44:25 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:44:26 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:44:27 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:44:28 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:44:29 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:02 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:03 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:04 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:05 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:06 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:07 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:45:11 2022 daemon.err ss-redir[26335]: 2022-12-08 14:45:11 ERROR: server recv: Operation timed out
Thu Dec 8 14:45:39 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:40 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:41 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:42 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:43 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:45:44 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:46:02 2022 daemon.err ss-redir[26335]: 2022-12-08 14:46:02 ERROR: server recv: Operation timed out
Thu Dec 8 14:46:16 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:46:17 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:46:18 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:46:19 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:46:20 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:46:21 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1000 milliseconds
Thu Dec 8 14:46:53 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:46:54 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:46:55 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:46:57 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:46:58 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:46:59 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 1001 milliseconds
Thu Dec 8 14:47:04 2022 daemon.err otb-daemon[3961]: curl: (28) Connection timed out after 5001 milliseconds
Thu Dec 8 14:47:14 2022 user.notice post-tracking-mptcp: if3 switched off
Thu Dec 8 14:47:14 2022 user.notice post-tracking-otb-autoroute: del default route for if3 using gateway 192.168.37.254 and metric 0
Thu Dec 8 14:47:14 2022 user.notice post-tracking-otb-autoroute: del 194.158.122.10 route for if3 using gateway 192.168.37.254 and metric 0
Thu Dec 8 14:47:14 2022 user.notice post-tracking-otb-autoroute: del 194.158.122.15 route for if3 using gateway 192.168.37.254 and metric 0
Thu Dec 8 14:47:14 2022 user.notice post-tracking-store-state: if3 tracking status changed to ERROR
Thu Dec 8 14:47:15 2022 user.notice post-tracking-otb-autoroute: add default route for tun0 using gateway 10.166.178.1 and metric 0
Thu Dec 8 14:47:16 2022 user.notice post-tracking-mptcp: if3 switched to on
Thu Dec 8 14:47:16 2022 user.notice post-tracking-otb-autoroute: add 194.158.122.10 route for if3 using gateway 192.168.37.254 and metric 0
Thu Dec 8 14:47:16 2022 user.notice post-tracking-otb-autoroute: add 194.158.122.15 route for if3 using gateway 192.168.37.254 and metric 0
Thu Dec 8 14:47:16 2022 user.notice post-tracking-store-state: if3 tracking status changed to OK
Thu Dec 8 14:47:34 2022 daemon.err otb-daemon[3961]: jq: invalid JSON text passed to --argjson
Thu Dec 8 14:47:34 2022 daemon.err otb-daemon[3961]: Use jq --help for help with command-line options,
Thu Dec 8 14:47:34 2022 daemon.err otb-daemon[3961]: or see the jq manpage, or online docs at https://stedolan.github.io/jq
Thu Dec 8 14:47:36 2022 daemon.err otb-daemon[3961]: curl: (28) Operation timed out after 1001 milliseconds with 0 bytes received
Bonjour @GilD3
Appeler le SAV OVH au +33 9 72 10 10 07.
Plutôt entre 8h et 9h le matin il y a moins d'attente.
Où déjà maintenant sur Twitter @ovh_support_fr
Le soucis initial est que la connexion internet de l'overthebox n'est pas effective.
Les logs de timeout sont un bug de la version v0.6.33 en cours de résolution où l'on ne vérifie pas que l'appel vers l'API s'effectue correctement avant de traiter le résultat. Ce soucis est causé par l'absence de connectivité, mais n'en est pas la cause.
Cordialement,
