Technical tip for increasing server capacity
Hello.
Beyond 20,000 visits, many of which are bots (or not), the database of https://www.argotheme.com/organecyberpresse/
IS crashing
It is currently: 500.58 MB / 2 GB
Thank you for guiding me
Hello @NacereddineB
This is the most effective measure to reduce the load. Add these rules at the beginning of your .htaccess file to block the crawlers that consume the most resources:
RewriteEngine On
RewriteCond %{HTTP_USER_AGENT} "AhrefsBot" [NC,OR]
RewriteCond %{HTTP_USER_AGENT} "SemrushBot" [NC,OR]
RewriteCond %{HTTP_USER_AGENT} "MJ12bot" [NC,OR]
RewriteCond %{HTTP_USER_AGENT} "PetalBot" [NC,OR]
RewriteCond %{HTTP_USER_AGENT} "DotBot" [NC]
RewriteRule .* - [F,L]
Reduce the crawl frequency with robots.txt
User-agent: *
Crawl-delay: 10
Can you give us more information about this? Which service do you have subscribed to? Do you have any open ticket?
We look forward to your response.
Sergio Turpín
Hello.
An open ticket: CS16863293
Affected hosting
argotheme.com
Are you the administrator or technical contact for the service?
yes
Additional information
Hello.
the database of https://www.argotheme.com/organecyberpresse/ crashes, the site is struggling, does not display and becomes unmanageable to add content.
I need technical advice to improve, including moving to a higher‑level plan.
Thank you
Thank you for your advice:
What service did you subscribe to?
This question is not precise enough:
At this point, I have this answer: “I am with Offer - PRO”
Hello :slight_smile:
@sturpin raised a very interesting point, the blocking of bots that can cause high resource consumption on hosting services, especially on databases, which can lead to service interruptions.
Regarding the data present in the database.
Under GDPR, OVHcloud support has no visibility into customers' data, so we will not be able to inform you about the cause of data saturation or the content the database contains. However, I invite you to connect to your database via phpMyAdmin to understand where this data comes from:
• Click on the reference of your hosting under the "Hosting" section,
• Go to the "Database" tab,
• Click the three dots to the right of your database to access phpMyAdmin.
For more information on this access, please refer to our guide: https://help.ovhcloud.com/csm/fr-web-hosting-creating-database?id=kb_article_view&sysparm_article=KB0053070#acceder-a-linterface-phpmyadmin
I also invite you to follow step‑by‑step the instructions in our guide on this topic to resolve this issue: https://docs.ovh.com/fr/hosting/database-overquota/
This documentation will show you how to find the root cause of this problem and how to fix it. If you do not have the technical skills to purge your database, I still encourage you to identify the source of the problem in order to resolve it, then proceed with restoring your database by following these steps:
• Click on your domain under the "Hosting" section.
• Go to the "Database" tab.
• Go to "Database".
• To the right of your database, click the three small dots,
• Click the three dots to the right of the desired backup to restore it.
For more details, please consult our guide: https://help.ovhcloud.com/csm/fr-web-cloud-db-restore-import-database?id=kb_article_view&sysparm_article=KB0051486
If the data that caused your database to become saturated is legitimate, you can migrate your database to one offering a larger storage capacity. Indeed, for large databases we offer the Web Cloud Database service: https://www.ovhcloud.com/fr/web-cloud/databases/
To migrate your current database to a Web Cloud Database, please follow these steps:
• Go to "Database".
• Click the three dots to the right of the backup to "Copy the database"
For more details, please follow our guide on this subject: https://help.ovhcloud.com/csm/fr-web-hosting-copy-transfer-database?id=kb_article_view&sysparm_article=KB0060504
Feel free to keep us updated on the situation.
Astérix
It's not a database saturation.
Since I provided this, it's at a quarter: "500.58 MB / 2 GB"
It's the more than 1,000 visits (requests) per hour that prevent proper functioning.
I see that you are using SPIP and your domain is behind Cloudflare. Malicious traffic should be filtered before it reaches your hosting.
I also see that the DNS servers have already been switched to Cloudflare :+1:
Do you have Bot Fight Mode enabled and WAF rules created, as well as AI bots blocked?
Additionally, you might consider installing the SPIP WAF plugin (https://contrib.spip.net/WAF) in your CMS.
Keep us informed :wink:
Sergio Turpín
En effet, le filtrage s'effectue. WAF et CloudFlare font le boulot. C'est la puissance du serveur qui fait défaut. J'ai avancé le chiffre qu'au-delà de 20000 requêtes, le quota semble être atteint... M
If I have to switch to another plan, I need it to be presented to me and assure the proper functioning of the site.
The OVH support ticket directs me to purchase. I bought in vain. However, it was not successful and I requested a refund, which was granted.
I am looking for a fair solution.
Hi @NacereddineB
I understand you’re looking for a fair solution. If you’ve already applied security measures and bot blocks, and the site is still crashing, it’s a sign that the shared resources of the Pro plan are insufficient for the request volume you’re receiving.
The next option is the Performance (https://www.ovhcloud.com/es-es/web-hosting/business) tier. It’s designed for demanding projects and gives you dedicated resources, plus an option to temporarily increase resources during traffic spikes. This prevents bot requests from choking your real visitors.
If the problem persists even with Performance, then the definitive solution would be a VPS, where you would have full control over the server and could tune the configuration to your needs.
Hope this helps,
Sergio Turpín
