Hi, i was trying to activate DNSSEC over my .it domain but actually this extesion it is not supported by OVH… anybody knows if and when they plan to implement it for .IT domains?
Thank you all in advance for any reply![]()
Hello @MassimilianoV ,
if the registry does not allow dnssec, OVHcloud does not offer it.
I will let you eventually turn to external solutions to find an alternative.
^FabL
Thank you for the quick reply @FabL , well, for what i know it's since 2018 that .it domains are allowed to use DNSSEC, depends on the registar, i mean if it is credited or not for registering by DNSSEC; here is the link to use to be credited https://auth.nic.it/auth/realms/registrar/protocol/openid-connect/auth?client_id=arp&redirect_uri=https%3A%2F%2Farp.nic.it%2Fhome%2Fhome&state=a3a28e00-91e7-4db7-8c72-a32bb68f4276&nonce=b556a8d7-7ce8-4930-ad71-ddd4354b2112&response_mode=fragment&response_type=code&scope=openid
And here the article that say DNSSEC it's available since Sept 2018 …
https://www.nic.it/it/news/2018/il-nuovo-portale-arp-i-registrar-e-laccreditamento-il-dnssec
Anyway, i will be glad if OVH will release this service for .it as well, but , eventually, what alternative could i find as you suggest?
Thank you in advance,
Max
Any news?
Nope, still doesn't work.
So you basically said, that OVH supports DNSSEC for .it domains?!? :expressionless:
Are you?
https://www.ovhcloud.com/pl/domains/tld/it/
vs
https://www.nic.it/en/news/2018/dnssec
I'm interested in transferring .it domain to OVH, but there no DNSSEC :expressionless:
May we ask for some valid information on this topic instead of corporate talk?
I'd like to enable DNSSEC too. The registry allows it. Could you contact your SW engineers and ask them to implement it?
Thank you
Hello, I would also like to be able to activate DNSSEC on my domain, but it's still not possible…
On Ovh's Italian site https://www.ovhcloud.com/it/domains/dnssec/">there is a page where OVH advertise Dnssec as included, but from the management interface you cannot activate it …
Hi FabL,
it's past more than 2 year but still we can't enable DNSSEC on our .it domains.
It's time to respond with a proper answer giving an ETA for this (advertised) feature or we have to move elsewhere.
Noooooo so bad!!! i bought a .it domain 5 minutes ago because i read that there was DNSSEC available and the first and only thing a did as i entered in my account was to enable DNSSEC… and i got a message that it's not available it's a fraud!!! i hope they'll refound me
NIC.it announced support for DNSSEC since January 2019:
https://www.nic.it/en/doc/2019/01net-al-il-protocollo-dnssec
FabL, as you can see here DNSSEC | Registro .it NIC.it supports DNSSEC since 2016
IHMO, answares like "if the registry does not allow dnssec, OVHcloud does not offer it." has to be verified before.
Regards
Hi everyone,
As registry support DNSEC since almost 10y, when OVH will offer it ?
Thanks
Regards
