Edge Network Firewall UDP 443
Hi.
Edge Network Firewall can't open UDP 443 port?
I opened ports:
TCP 80
TCP 443
UDP 443
but with Edge Network Firewall enabled I don't get http3
I also tried to allow all IP addresses of version 4, but it still doesn’t work.
But as soon as I disable Edge Network Firewall, HTTP3 starts working without any problems.
Has anyone encountered such problems?
"The Edge Network Firewall does not support the QUIC protocol."
