Hello,
I want to manage a part of my site with limited access using a unique password per user.
I know how to protect this area with .htaccess, but I would like each user to have their own identifier.
Hello @LeonP
In your .htpasswd file you add as many users as you need, each with a different username and its associated password, one per line.
Albert:motpassAlbert
Jules:motdepassJules
Leo:motdepasseLeo
OK, thanks.
I'll try to get all that done and, if I still have an issue, I'll be back.
Léon
Do not forget that the password must be encrypted as indicated in the OVH docs
mmmmhhh, I'm not sure about what you're suggesting. Apache is very tolerant in that case.
Not long ago, I was able to verify that a clear‑text password was accepted.
If the information to protect is truly sensitive, you should opt for salted, hashed encryption.
Hello @fritz2cat
So I was carefully following OVH's recommendations and had never tried using the clear‑text password in the htpasswd.
I just tried but it doesn't work with the clear‑text password.
Thanks for getting back to me!
These won’t be sensitive information, just information and documents available only to club members.
Good morning @LeonP
Take a look at this thread
Dossier protégé par mot d epasse - #3 par sturpin
Kind regards,
Sergio Turpín
