Hello,
Since I haven't received a response to my ticket, I'm turning to the community.
I am on a personal plan.
Is it possible to host a web application created with Claude Code on a subdomain, and can Node.js be enabled?
Thanks
Hello,
Thanks
Hello @FlorentW1
I have two questions for you:
First: is node.js available on personal hosting?
No, it is not available.
Second: using a PHP website development provided by an artificial intelligence, whether Claude or another, requires certain precautions:
Check every line of code and understand it in order to avoid unpleasant surprises in the short or long term.
Hi @FlorentW1
I agree with what @Gaston says, it’s not the same to generate code with an AI as to understand it and maintain it in the long term. I recommend that you review the code generated by Claude Code line by line and understand its logic so you can troubleshoot problems and make future evolutions. That will save you a lot of headaches ![]()
To host your application on your domain and use Node.js, you won’t be able to do it with only the Personal offering. I suggest you explore the world of VPSs or the Cloud Web range to get the necessary support and, at the same time, take the advice to review the generated code.
Best regards,
Sergio Turpín
For an AI‑generated website, I’d look at astro.build + GitHub + Cloudflare Workers.
There’s enough there to almost fully automate the whole process for quite impressive results.
Hello,
Thanks to everyone for your replies, I have switched to a competitor for this site. OVH only changes its pricing, not its services.
Where have you finally ended up? And what improvement have you found with that new provider? (curiosity)
Regards ![]()
Sergio Turpín
