my ovh domain is connected by a server, the domain when i write it should open swagger to reach my api sometimes the domain open and sometimes it says that site under construction i don't know why?
this is my url : https://kwayes.com
Hi @NejibB1
Paragraphe : G - WordPress - Mise en place de la Zone DNS pour le domaine Example.com
Paragraphe : H - WordPress - Mise en place du Multisite pour le domaine Example.com
it doesn't help me and i don't know what i should do and why sometime it's working and sometimes no and i need to know how to add my server ip to the domain!!
Hello,
simply edit your DNS zone.
Cordially, janus57
can you tell me how in details please
See --> **https://www.wordetweb.com/word-et-web/WORDPRESS-guide-installation-de-WordPress-premier-domaine-chez-OVH-FR.htm CMS - WordPress - Installation chez OVH**
Paragraphe : G - WordPress - **Mise en place de la Zone DNS pour le domaine Example.com**
Hello,
here is the OVH guide : https://docs.ovh.com/us/en/domains/web_hosting_how_to_edit_my_dns_zone/
Cordially, janus57
should the dns zone be the same for the ipv4?
because my server ip is different from the ipv4
Hello,
Your question make no sense.
Be more precise for your questions.
Cordially, janus57
Hello,
the screen you show is a web hosting, you cannot change this IP…
Cordially, janus57
how can i change the ipv4 here?
C'est l'inverse.
C'est cette adresse IP qu'il faut mettre dans la Zone DNS filtre A
but this when i put it in the DNS zone the site appear that it's under construction but when i put the server ip in DNS Zone instead of ipv4 it works here it is not the same but the domain is working
Hello,
you forgot IPv6.
Cordially, janus57
how to get the IPv6 from my server to edit it in OVH Domain?
sorry.i am asking too much
Hello,
ask the provider where you pay your server.
Cordially, janus57
ok i got it, the last thing as you see above in the 2 screenshots i have attached is there a problem to be different that the IPv4 not the same as it appear in DNS Zone ?
