I need to connect my OVH-domain with a website hosted at Squarespace. Problems with DNS
Cannot configure DNS properly in order to connect my Squarespace website with the OHV Domain
Unfortunately when I try to create a new DNS record OR modify an existing DNS record, I cannot find the field "Host" which is necessary for the modification - Squarespace gave me a list of changes, and there is a value (@ or www or something else) whithin every single modification that must be done, in order to CONNECT my domain at OHV with my Squarespace Website.
Can somebody please help?
Kind regards, Tomasz
Hello everyone,
hi! did you find an answer for that question? i have teh same issue
thanx
Maxime
Hello;
This should be done via c-name record.
!image|670x500
So you would make domain c-name 1website.domain.comwebsite.domain.com then point to > verify.squarespace.com or what ever c-name they provided you.
If you have any issues please let me know will check further into this for you.
