Impossible d'envoyer des mails vers Gmail
Nous avons un compte Exchange et il nous est impossible d'envoyer des mails vers Gmail. Voici le message qui nous revient :
This is the mail system at host mo547.mail-out.ovh.net.
I'm sorry to have to inform you that your message could not
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to postmaster.
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The mail system
: host gmail-smtp-in.l.google.com[173.194.76.27]
said: 550-5.7.26 This mail is unauthenticated, which poses a security risk
to the 550-5.7.26 sender and Gmail users, and has been blocked. The sender
must 550-5.7.26 authenticate with at least one of SPF or DKIM. For this
message, 550-5.7.26 DKIM checks did not pass and SPF check for
[jonathanlevens.be] did 550-5.7.26 not pass with ip: [46.105.38.168]. The
sender should visit 550-5.7.26
https://support.google.com/mail/answer/81126#authentication for 550 5.7.26
instructions on setting up authentication.
f6-20020adffcc6000000b0030fcdaaac9csi9158406wrs.749 - gsmtp (in reply to
end of DATA command)
Reporting-MTA: dns; mo547.mail-out.ovh.net
X-Postfix-Queue-ID: E917820B63
X-Postfix-Sender: rfc822; info@jonathanlevens.be
Arrival-Date: Tue, 4 Jul 2023 15:03:08 +0000 (UTC)
Final-Recipient: rfc822; levensjonathan@gmail.com
Original-Recipient: rfc822;levensjonathan@gmail.com
Action: failed
Status: 5.7.26
Remote-MTA: dns; gmail-smtp-in.l.google.com
Diagnostic-Code: smtp; 550-5.7.26 This mail is unauthenticated, which poses a
security risk to the 550-5.7.26 sender and Gmail users, and has been
blocked. The sender must 550-5.7.26 authenticate with at least one of SPF
or DKIM. For this message, 550-5.7.26 DKIM checks did not pass and SPF
check for [jonathanlevens.be] did 550-5.7.26 not pass with ip:
[46.105.38.168]. The sender should visit 550-5.7.26
Return-Path:
Received: from ex4.mail.ovh.net (unknown [10.109.138.51])
by mo547.mail-out.ovh.net (Postfix) with ESMTPS id E917820B63
for ; Tue, 4 Jul 2023 15:03:08 +0000 (UTC)
Received: from DAG1EX1.indiv4.local (172.16.2.1) by DAG1EX2.indiv4.local
(172.16.2.2) with Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.1.2507.27; Tue, 4 Jul
2023 17:03:08 +0200
Received: from DAG1EX1.indiv4.local ([fe80::94de:547f:3514:7c64]) by
DAG1EX1.indiv4.local ([fe80::94de:547f:3514:7c64%2]) with mapi id
15.01.2507.027; Tue, 4 Jul 2023 17:03:08 +0200
To: Jonathan Levens
Subject:
Thread-Index: AQHZroikEIj7TaZ9X0+vCdoNQjExmQ==
Message-ID: <4061FEE2-13BC-4049-A8A1-C966A5F0D748@jonathanlevens.be>
Accept-Language: fr-FR, en-US
Content-Language: en-US
X-MS-Has-Attach: yes
X-MS-TNEF-Correlator:
x-originating-ip: [109.134.241.36]
Content-Type: multipart/related;
boundary="004_4061FEE213BC4049A8A1C966A5F0D748jonathanlevensbe";
type="multipart/alternative"
MIME-Version: 1.0
X-Ovh-Tracer-Id: 3795408589814755165
X-VR-SPAMSTATE: OK
X-VR-SPAMSCORE: -90
X-VR-SPAMCAUSE: gggruggvucftvghtrhhoucdtuddrgedviedrudeggdekfecutefuodetggdotefrodftvfcurfhrohhfihhlvgemucfqggfjpdevjffgvefmvefgnecuuegrihhlohhuthemucehtddtnecusecvtfgvtghiphhivghnthhsucdlqddutddtmdengfhmphhthicushhusghjvggtthculddutddmnecujfgurhephffvufhtfffkihgtggesrhdtmhertddtjeenucfhrhhomhepfdflrdcunffgggfgpffuucdqucfngfgggffpufcuteftvefjkffvgfevvffgufcuufftnfdfuceoihhnfhhosehjohhnrghthhgrnhhlvghvvghnshdrsggvqeenucggtffrrghtthgvrhhnpeeuueehteetveehfedvudfhheejffeuudfhkeeiieegvefgiedvheeuvedvgeelheenucffohhmrghinhepjhhonhgrthhhrghnlhgvvhgvnhhsrdgsvgenucfkphepuddvjedrtddrtddruddpuddtledrudefgedrvdeguddrfeeinecuvehluhhsthgvrhfuihiivgeptdenucfrrghrrghmpehinhgvthepuddvjedrtddrtddruddpmhgrihhlfhhrohhmpeeoihhnfhhosehjohhnrghthhgrnhhlvghvvghnshdrsggvqedpnhgspghrtghpthhtohepuddprhgtphhtthhopehlvghvvghnshhjohhnrghthhgrnhesghhmrghilhdrtghomhdpoffvtefjohhsthepmhhoheegjedpmhhouggvpehsmhhtphhouhht
Avez-vous une idée de ce que nous devons faire? D'avance un grand merci!
vous avez 2 SPF => violation de protocole.
Supprimer l'entrée "v=spf1 include:_spf.google.com ~all" si vous n'avez pas de compte google workspace.
Bonjour, <br /><br />J&#39;ai également un problème lorsque j&#39;essaie d&#39;envoyer des mails à des boites gmail. Je reçois toujours le message d&#39;erreur suivant : <br /><br />This is the mail system at host mo548.mail-out.ovh.net.<br /><br />I&#39;m sorry to have to inform you that your message could not<br />be delivered to one or more recipients. It&#39;s attached below.<br /><br />For further assistance, please send mail to postmaster.<br /><br />If you do so, please include this problem report. You can<br />delete your own text from the attached returned message.<br /><br />                  The mail system<br /><br />gmail.com&gt;: host gmail-smtp-in.l.google.com[74.125.206.27] said:<br />   550-5.7.26 This mail is unauthenticated, which poses a security risk to the<br />   550-5.7.26 sender and Gmail users, and has been blocked. The sender must<br />   550-5.7.26 authenticate with at least one of SPF or DKIM. For this message,<br />   550-5.7.26 DKIM checks did not pass and SPF check for [cdgpartners.com] did<br />   not 550-5.7.26 pass with ip: [188.165.58.48]. The sender should visit<br />   550-5.7.26  https://support.google.com/mail/answer/81126#authentication for<br />   550 5.7.26 instructions on setting up authentication.<br />   m27-20020a05600c3b1b00b003fb9f3ea818si791873wms.171 - gsmtp (in reply to<br />   end of DATA command)<br />Reporting-MTA: dns; mo548.mail-out.ovh.net<br />X-Postfix-Queue-ID: 183C5202AA<br />X-Postfix-Sender: rfc822; XXX@cdgpartners.com<br />Arrival-Date: Wed,  5 Jul 2023 07:38:38 &#43;0000 (UTC)<br /><br />Final-Recipient: rfc822; XXX@gmail.com<br />Original-Recipient: rfc822;XXX@gmail.com<br />Action: failed<br />Status: 5.7.26<br />Remote-MTA: dns; gmail-smtp-in.l.google.com<br />Diagnostic-Code: smtp; 550-5.7.26 This mail is unauthenticated, which poses a<br />   security risk to the 550-5.7.26 sender and Gmail users, and has been<br />   blocked. The sender must 550-5.7.26 authenticate with at least one of SPF<br />   or DKIM. For this message, 550-5.7.26 DKIM checks did not pass and SPF<br />   check for [cdgpartners.com] did not 550-5.7.26 pass with ip:<br />   [188.165.58.48]. The sender should visit 550-5.7.26<br />   https://support.google.com/mail/answer/81126#authentication for 550 5.7.26<br />   instructions on setting up authentication.<br />   m27-20020a05600c3b1b00b003fb9f3ea818si791873wms.171 - gsmtp<br /><br />J&#39;ai déjà modifié un SPF en TXT comme il est dit sur d&#39;autres forums OVH, en ayant bien supprimé l&#39;ancien pour éviter de créer des conflits. <br /><br />Je fais donc appelle à votre aide et vous remercie par avance pour votre réponse. <br /><br />Bonne journée !
J'ai déjà modifié un SPF en TXT comme il est dit sur d'autres forums OVH, en ayant bien supprimé l'ancien pour éviter de créer des conflits.
non vous n'avez pas de SPF du tout, il faut en mettre un dans votre zone DNS qui est chez WIX.
J&#39;ai un problème similaire depuis plusieurs semaines. Impossible d&#39;envoyer des mails aux adresses gmail. Quelle solution avez-vous à me proposer ? Merci<br /><br /><br />This is the mail system at host mo544.mail-out.ovh.net.<br /><br />I&#39;m sorry to have to inform you that your message could not be delivered to one or more recipients. It&#39;s attached below.<br /><br />For further assistance, please send mail to postmaster.<br /><br />If you do so, please include this problem report. You can delete your own text from the attached returned message.<br /><br />                   The mail system<br /><br />gmail.com&gt;: host gmail-smtp-in.l.google.com[173.194.76.27] said:<br />    550-5.7.26 This mail is unauthenticated, which poses a security risk to the<br />    550-5.7.26 sender and Gmail users, and has been blocked. The sender must<br />    550-5.7.26 authenticate with at least one of SPF or DKIM. For this message,<br />    550-5.7.26 DKIM checks did not pass and SPF check for [sevegaillard.fr] did<br />    not 550-5.7.26 pass with ip: [46.105.37.77]. The sender should visit<br />    550-5.7.26  https://support.google.com/mail/answer/81126#authentication for<br />    550 5.7.26 instructions on setting up authentication.<br />    e13-20020a056000120d00b0031125007a23si6550498wrx.1014 - gsmtp (in reply to<br />    end of DATA command)
Même solution, créer une entre SPF chez WIX.
J'ai un problème similaire que je ne parviens pas à résoudre concernant l'envoi de courriel gmail en échec.
Voici le courriel que je recois :
Merci par avance pour votre aide.
E-mail : xxxxxx@gmail.com
Erreurs : 1
Message : Final-Recipient: rfc822; maxime.boel81@gmail.com
Original-Recipient: rfc822;maxime.boel81@gmail.com
Action: failed
Status: 5.7.26
Remote-MTA: dns; 1in.l.google.comin.l.google.com
Diagnostic-Code: smtp; 550-5.7.26 Unauthenticated email from gmail.com is not
accepted due to domain's 550-5.7.26 DMARC policy. Please
contact the
administrator of gmail.com domain 550-5.7.26 if this was a legitimate mail.
Please visit 550-5.7.26 https://support.google.com/mail/answer/2451690 to
learn about the 550 5.7.26 DMARC initiative.
ss6-20020a05620a3ac600b007758e5dba35si2703772qkn.484 - gsmtp
Voici l'erreur affiché dans la console script email de mon compte OVH :
Final-Recipient: rfc822; xxxx@gmail.com
Original-Recipient: rfc822;xxxx@gmail.com
Action: failed
Status: 5.7.26
contact the
faite votre propre topic car là vous essayez d'usurper une adresse en @gmail.com comme adresse d’envoi.
Note : les réponses seront faites dans le nouveau topic.
