Impossible d'envoyer sur adresses gmail
mon nom de domaine est innov-concept.fr.
Mes boîtes mails ont été créées mais les envois sur les boîtes gmail reviennent en non distribué.
Avez-vous une solution svp ?
il faudrait le message d'erreur au complet pour vous aider.
Votre entrée SPF est :
`"v=spf1 +all"`
Aucune chance que cela fonctionne comme ça.
Regardez par ici : https://docs.ovh.com/fr/domains/le-champ-spf/
Voici le message de retour :<br /><br />This is the mail system at host mo559.mail-out.ovh.net.<br /><br />I&#39;m sorry to have to inform you that your message could not<br />be delivered to one or more recipients. It&#39;s attached below.<br /><br />For further assistance, please send mail to postmaster.<br /><br />If you do so, please include this problem report. You can<br />delete your own text from the attached returned message.<br /><br />                   The mail system<br /><br />gmail.com&gt;: host gmail-smtp-in.l.google.com[66.102.1.26]<br />    said: 550-5.7.1 [188.165.60.123      12] Our system has detected that this<br />    message is 550-5.7.1 likely unsolicited mail. To reduce the amount of spam<br />    sent to Gmail, 550-5.7.1 this message has been blocked. Please visit<br />    550-5.7.1  https://support.google.com/mail/?p&#61;UnsolicitedMessageError 550<br />    5.7.1  for more information.<br />    y8-20020a05600015c800b0022e6178bd8dsi1525266wry.475 - gsmtp (in reply to<br />    end of DATA command)<br />Reporting-MTA: dns; mo559.mail-out.ovh.net<br />X-Postfix-Queue-ID: 948D32122C<br />X-Postfix-Sender: rfc822; ftrupin@1concept.frconcept.fr<br />Arrival-Date: Fri, 14 Oct 2022 08:45:43 &#43;0000 (UTC)<br /><br />Final-Recipient: rfc822; a.danslairdutemps@gmail.com<br />Original-Recipient: rfc822;a.danslairdutemps@gmail.com<br />Action: failed<br />Status: 5.7.1<br />Remote-MTA: dns; gmail-smtp-in.l.google.com<br />Diagnostic-Code: smtp; 550-5.7.1 [188.165.60.123      12] Our system has<br />    detected that this message is 550-5.7.1 likely unsolicited mail. To reduce<br />    the amount of spam sent to Gmail, 550-5.7.1 this message has been blocked.<br />    Please visit 550-5.7.1<br />    https://support.google.com/mail/?p&#61;UnsolicitedMessageError 550 5.7.1  for<br />    more information. y8-20020a05600015c800b0022e6178bd8dsi1525266wry.475 -<br />    gsmtp
J'ai modifié le SFP et ça fonctionne.
Merci beaucoup :wink:
