IP address is not updating on OVH web-panel
I created instance with debian 10 image, and attached vRack network that I created earilier (I created subnet without DHCP). But my debian 10 instance on run got IP address from my vrack network subnet range. I changed the IP to another static IP address from instance, and new static IP address was set, but OVH web-panel still showing the old IP address. What should I do so my OVH web-panel will show correct IP address?
!image|690x41
