I highly suggest you to contact the technical support for such an issue, the team will be able to check with you by using your nic and project ID In the meantime and if you are familiar with S3 API and if you stored your S3 user credentials (S3 access and secret keys - Do not share them here!), could you check using the CLI if you can access your bucket or not?
