Java n'a plus assez de mémoire pour continuer
Bonjour tout le monde.
J'ai actuellement un vps au dessus il y a installer un serveur minecraft (uniquement)
Je rencontre un erreur tellement rare que personne n'a pue m'aider…
C'est incroyable je suis le seul sur cette terre à rencontrer ce problème (on m'a même dit que j'étais maudit)
J'utilise seulement java JDK 17.
Voici le crash log:
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 10737418240 bytes for committing reserved memory.
# Possible reasons:
# The system is out of physical RAM or swap space
# The process is running with CompressedOops enabled, and the Java Heap may be blocking the growth of the native heap
# Possible solutions:
# Reduce memory load on the system
# Increase physical memory or swap space
# Check if swap backing store is full
# Decrease Java heap size (-Xmx/-Xms)
# Decrease number of Java threads
# Decrease Java thread stack sizes (-Xss)
# Set larger code cache with -XX:ReservedCodeCacheSize=
# JVM is running with Zero Based Compressed Oops mode in which the Java heap is
# placed in the first 32GB address space. The Java Heap base address is the
# maximum limit for the native heap growth. Please use -XX:HeapBaseMinAddress
# to set the Java Heap base and to place the Java Heap above 32GB virtual address.
# This output file may be truncated or incomplete.
# Out of Memory Error (os_linux.cpp:2728), pid=26158, tid=26159
# JRE version: (17.0+35) (build )
# Java VM: Java HotSpot™ 64-Bit Server VM (17+35-LTS-2724, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
--------------- S U M M A R Y ------------
Command Line: -Xms10G -Xmx29G -Dterminal.jline=false -Dterminal.ansi=true paper-1.17.1-308.jar
Host: Intel Core Processor (Haswell, no TSX), 8 cores, 30G, Debian GNU/Linux 10 (buster)
Time: Tue Oct 12 19:08:49 2021 UTC elapsed time: 0.012637 seconds (0d 0h 0m 0s)
--------------- T H R E A D ---------------
Current thread (0x00007f4f4c023070): JavaThread "Unknown thread" [_thread_in_vm, id=26159, stack(0x00007f4f52a3e000,0x00007f4f52b3f000)]
Stack: [0x00007f4f52a3e000,0x00007f4f52b3f000], sp=0x00007f4f52b3d3f0, free space=1020k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
V [libjvm.so+0xe0af81] VMError::report_and_die(int, char const*, char const*, __va_list_tag*, Thread*, unsigned char*, void*, void*, char const*, int, unsigned long)+0x1a1
V [libjvm.so+0xe0bb4d] VMError::report_and_die(Thread*, char const*, int, unsigned long, VMErrorType, char const*, __va_list_tag*)+0x2d
V [libjvm.so+0x5d6263] report_vm_out_of_memory(char const*, int, unsigned long, VMErrorType, char const*, …)+0xc3
V [libjvm.so+0xbe5528] os::pd_commit_memory_or_exit(char*, unsigned long, unsigned long, bool, char const*)+0xd8
V [libjvm.so+0xbde6ad] os::commit_memory_or_exit(char*, unsigned long, unsigned long, bool, char const*)+0x1d
V [libjvm.so+0x7002de] G1PageBasedVirtualSpace::commit(unsigned long, unsigned long)+0x18e
V [libjvm.so+0x714c01] G1RegionsLargerThanCommitSizeMapper::commit_regions(unsigned int, unsigned long, WorkGang*)+0x1a1
V [libjvm.so+0x7a64c8] HeapRegionManager::commit_regions(unsigned int, unsigned long, WorkGang*)+0x58
V [libjvm.so+0x7a7885] HeapRegionManager::expand(unsigned int, unsigned int, WorkGang*)+0x35
V [libjvm.so+0x7a7a9e] HeapRegionManager::expand_by(unsigned int, WorkGang*)+0x7e
V [libjvm.so+0x6babff] G1CollectedHeap::expand(unsigned long, WorkGang*, double*)+0xef
V [libjvm.so+0x6bb3af] G1CollectedHeap::initialize()+0x72f
V [libjvm.so+0xdbc81d] universe_init()+0xbd
V [libjvm.so+0x7c8147] init_globals()+0x37
V [libjvm.so+0xd93a4f] Threads::create_vm(JavaVMInitArgs*, bool*)+0x39f
V [libjvm.so+0x896141] JNI_CreateJavaVM+0x51
C [libjli.so+0x3a8f] JavaMain+0x8f
C [libjli.so+0x7ee9] ThreadJavaMain+0x9
--------------- P R O C E S S ---------------
Threads class SMR info:
_java_thread_list=0x00007f4f53f2a620, length=0, elements={
Java Threads: ( => current thread )
Other Threads:
0x00007f4f4c064200 GCTaskThread "GC Thread#0" [stack: 0x00007f4f51da4000,0x00007f4f51ea4000] [id=26160]
0x00007f4f4c074000 ConcurrentGCThread "G1 Main Marker" [stack: 0x00007f4f51ca2000,0x00007f4f51da2000] [id=26161]
0x00007f4f4c074f60 ConcurrentGCThread "G1 Conc#0" [stack: 0x00007f4f51ba0000,0x00007f4f51ca0000] [id=26162]
[error occurred during error reporting (printing all threads), id 0xb, SIGSEGV (0xb) at pc=0x00007f4f5339f840]
VM state: not at safepoint (not fully initialized)
VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event])
[0x00007f4f4c020b00] Heap_lock - owner thread: 0x00007f4f4c023070
Heap address: 0x00000000c0000000, size: 29696 MB, Compressed Oops mode: Zero based, Oop shift amount: 3
CDS archive(s) mapped at: [0x0000000000000000-0x0000000000000000-0x0000000000000000), size 0, SharedBaseAddress: 0x0000000800000000, ArchiveRelocationMode: 0.
Narrow klass base: 0x0000000000000000, Narrow klass shift: 0, Narrow klass range: 0x0
GC Precious Log:
Heap:
garbage-first heap total 0K, used 0K [0x00000000c0000000, 0x0000000800000000)
region size 16384K, 0 young (0K), 0 survivors (0K)
[error occurred during error reporting (printing heap information), id 0xb, SIGSEGV (0xb) at pc=0x00007f4f53955a6a]
GC Heap History (0 events):
No events
Deoptimization events (0 events):
No events
Classes unloaded (0 events):
No events
Classes redefined (0 events):
No events
Internal exceptions (0 events):
No events
VM Operations (0 events):
No events
Events (2 events):
Event: 0.003 Protecting memory [0x00007f4f52a3e000,0x00007f4f52a42000] with protection modes 0
Event: 0.004 Loaded shared library /usr/lib/jvm/jdk-17/lib/libjava.so
Dynamic libraries:
340000000-800000000 —p 00000000 00:00 0
564d2e310000-564d2e311000 r-xp 00000000 08:01 132785 /usr/lib/jvm/jdk-17/bin/java
564d2e312000-564d2e313000 r–p 00001000 08:01 132785 /usr/lib/jvm/jdk-17/bin/java
564d2e313000-564d2e314000 rw-p 00002000 08:01 132785 /usr/lib/jvm/jdk-17/bin/java
564d2fe16000-564d2fe37000 rw-p 00000000 00:00 0 [heap]
7f4ee2000000-7f4ee4000000 rw-p 00000000 00:00 0
7f4ee4000000-7f4ee4021000 rw-p 00000000 00:00 0
7f4ee4021000-7f4ee8000000 —p 00000000 00:00 0
7f4ee8000000-7f4ee8021000 rw-p 00000000 00:00 0
7f4ee8021000-7f4eec000000 —p 00000000 00:00 0
7f4eec000000-7f4eec021000 rw-p 00000000 00:00 0
7f4eec021000-7f4ef0000000 —p 00000000 00:00 0
7f4ef096b000-7f4f3576b000 —p 00000000 00:00 0
7f4f3576b000-7f4f359db000 rwxp 00000000 00:00 0
7f4f359db000-7f4f35cfd000 —p 00000000 00:00 0
7f4f35cfd000-7f4f35f6d000 rwxp 00000000 00:00 0
7f4f35f6d000-7f4f3d234000 —p 00000000 00:00 0
7f4f3d234000-7f4f3d4a4000 rwxp 00000000 00:00 0
7f4f3d4a4000-7f4f4476b000 —p 00000000 00:00 0
7f4f4476b000-7f4f4c000000 r–s 00000000 08:01 132717 /usr/lib/jvm/jdk-17/lib/modules
7f4f4c000000-7f4f4c0a4000 rw-p 00000000 00:00 0
7f4f4c0a4000-7f4f50000000 —p 00000000 00:00 0
7f4f50fe9000-7f4f51b9e000 rw-p 00000000 00:00 0
7f4f51b9e000-7f4f51b9f000 —p 00000000 00:00 0
7f4f51b9f000-7f4f51ca0000 rw-p 00000000 00:00 0
7f4f51ca0000-7f4f51ca1000 —p 00000000 00:00 0
7f4f51ca1000-7f4f51da2000 rw-p 00000000 00:00 0
7f4f51da2000-7f4f51da3000 —p 00000000 00:00 0
7f4f51da3000-7f4f52812000 rw-p 00000000 00:00 0
7f4f52812000-7f4f528f8000 —p 00000000 00:00 0
7f4f528f8000-7f4f528fd000 rw-p 00000000 00:00 0
7f4f528fd000-7f4f529e3000 —p 00000000 00:00 0
7f4f529e3000-7f4f529e8000 rw-p 00000000 00:00 0
7f4f529e8000-7f4f529ef000 —p 00000000 00:00 0
7f4f529ef000-7f4f52a13000 r-xp 00000000 08:01 132719 /usr/lib/jvm/jdk-17/lib/libjava.so
7f4f52a13000-7f4f52a14000 —p 00024000 08:01 132719 /usr/lib/jvm/jdk-17/lib/libjava.so
7f4f52a14000-7f4f52a15000 r–p 00024000 08:01 132719 /usr/lib/jvm/jdk-17/lib/libjava.so
7f4f52a15000-7f4f52a16000 rw-p 00025000 08:01 132719 /usr/lib/jvm/jdk-17/lib/libjava.so
7f4f52a16000-7f4f52a17000 rw-p 00000000 00:00 0
7f4f52a17000-7f4f52a1f000 rw-s 00000000 08:01 393506 /tmp/hsperfdata_root/26158
7f4f52a1f000-7f4f52a3a000 r-xp 00000000 08:01 132683 /usr/lib/jvm/jdk-17/lib/libjimage.so
7f4f52a3a000-7f4f52a3b000 —p 0001b000 08:01 132683 /usr/lib/jvm/jdk-17/lib/libjimage.so
7f4f52a3b000-7f4f52a3d000 r–p 0001b000 08:01 132683 /usr/lib/jvm/jdk-17/lib/libjimage.so
7f4f52a3d000-7f4f52a3e000 rw-p 0001d000 08:01 132683 /usr/lib/jvm/jdk-17/lib/libjimage.so
7f4f52a3e000-7f4f52a42000 —p 00000000 00:00 0
7f4f52a42000-7f4f52b3f000 rw-p 00000000 00:00 0
7f4f52b3f000-7f4f52b4c000 r–p 00000000 08:01 2000 /usr/lib/x86_64-linux-gnu/libm-2.28.so
7f4f52b4c000-7f4f52beb000 r-xp 0000d000 08:01 2000 /usr/lib/x86_64-linux-gnu/libm-2.28.so
7f4f52beb000-7f4f52cc0000 r–p 000ac000 08:01 2000 /usr/lib/x86_64-linux-gnu/libm-2.28.so
7f4f52cc0000-7f4f52cc1000 r–p 00180000 08:01 2000 /usr/lib/x86_64-linux-gnu/libm-2.28.so
7f4f52cc1000-7f4f52cc2000 rw-p 00181000 08:01 2000 /usr/lib/x86_64-linux-gnu/libm-2.28.so
7f4f52cc2000-7f4f52cc4000 r–p 00000000 08:01 3737 /usr/lib/x86_64-linux-gnu/librt-2.28.so
7f4f52cc4000-7f4f52cc8000 r-xp 00002000 08:01 3737 /usr/lib/x86_64-linux-gnu/librt-2.28.so
7f4f52cc8000-7f4f52cca000 r–p 00006000 08:01 3737 /usr/lib/x86_64-linux-gnu/librt-2.28.so
7f4f52cca000-7f4f52ccb000 r–p 00007000 08:01 3737 /usr/lib/x86_64-linux-gnu/librt-2.28.so
7f4f52ccb000-7f4f52ccc000 rw-p 00008000 08:01 3737 /usr/lib/x86_64-linux-gnu/librt-2.28.so
7f4f52ccc000-7f4f53df2000 r-xp 00000000 08:01 132676 /usr/lib/jvm/jdk-17/lib/server/libjvm.so
7f4f53df2000-7f4f53df3000 —p 01126000 08:01 132676 /usr/lib/jvm/jdk-17/lib/server/libjvm.so
7f4f53df3000-7f4f53ea8000 r–p 01126000 08:01 132676 /usr/lib/jvm/jdk-17/lib/server/libjvm.so
7f4f53ea8000-7f4f53edb000 rw-p 011db000 08:01 132676 /usr/lib/jvm/jdk-17/lib/server/libjvm.so
7f4f53edb000-7f4f53f37000 rw-p 00000000 00:00 0
7f4f53f37000-7f4f53f59000 r–p 00000000 08:01 1997 /usr/lib/x86_64-linux-gnu/libc-2.28.so
7f4f53f59000-7f4f540a1000 r-xp 00022000 08:01 1997 /usr/lib/x86_64-linux-gnu/libc-2.28.so
7f4f540a1000-7f4f540ed000 r–p 0016a000 08:01 1997 /usr/lib/x86_64-linux-gnu/libc-2.28.so
7f4f540ed000-7f4f540ee000 —p 001b6000 08:01 1997 /usr/lib/x86_64-linux-gnu/libc-2.28.so
7f4f540ee000-7f4f540f2000 r–p 001b6000 08:01 1997 /usr/lib/x86_64-linux-gnu/libc-2.28.so
7f4f540f2000-7f4f540f4000 rw-p 001ba000 08:01 1997 /usr/lib/x86_64-linux-gnu/libc-2.28.so
7f4f540f4000-7f4f540f8000 rw-p 00000000 00:00 0
7f4f540f8000-7f4f540f9000 r–p 00000000 08:01 1999 /usr/lib/x86_64-linux-gnu/libdl-2.28.so
7f4f540f9000-7f4f540fa000 r-xp 00001000 08:01 1999 /usr/lib/x86_64-linux-gnu/libdl-2.28.so
7f4f540fa000-7f4f540fb000 r–p 00002000 08:01 1999 /usr/lib/x86_64-linux-gnu/libdl-2.28.so
7f4f540fb000-7f4f540fc000 r–p 00002000 08:01 1999 /usr/lib/x86_64-linux-gnu/libdl-2.28.so
7f4f540fc000-7f4f540fd000 rw-p 00003000 08:01 1999 /usr/lib/x86_64-linux-gnu/libdl-2.28.so
7f4f540fd000-7f4f54103000 r–p 00000000 08:01 3735 /usr/lib/x86_64-linux-gnu/libpthread-2.28.so
7f4f54103000-7f4f54112000 r-xp 00006000 08:01 3735 /usr/lib/x86_64-linux-gnu/libpthread-2.28.so
7f4f54112000-7f4f54118000 r–p 00015000 08:01 3735 /usr/lib/x86_64-linux-gnu/libpthread-2.28.so
7f4f54118000-7f4f54119000 r–p 0001a000 08:01 3735 /usr/lib/x86_64-linux-gnu/libpthread-2.28.so
7f4f54119000-7f4f5411a000 rw-p 0001b000 08:01 3735 /usr/lib/x86_64-linux-gnu/libpthread-2.28.so
7f4f5411a000-7f4f5411e000 rw-p 00000000 00:00 0
7f4f5411e000-7f4f5412d000 r-xp 00000000 08:01 132712 /usr/lib/jvm/jdk-17/lib/libjli.so
7f4f5412d000-7f4f5412e000 r–p 0000e000 08:01 132712 /usr/lib/jvm/jdk-17/lib/libjli.so
7f4f5412e000-7f4f5412f000 rw-p 0000f000 08:01 132712 /usr/lib/jvm/jdk-17/lib/libjli.so
7f4f5412f000-7f4f5414b000 r-xp 00000000 08:01 4687 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
7f4f5414b000-7f4f5434b000 —p 0001c000 08:01 4687 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
7f4f5434b000-7f4f5434c000 r–p 0001c000 08:01 4687 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
7f4f5434c000-7f4f5434d000 rw-p 0001d000 08:01 4687 /usr/lib/x86_64-linux-gnu/libz.so.1.2.11
7f4f5434d000-7f4f5434f000 rw-p 00000000 00:00 0
7f4f54351000-7f4f54352000 —p 00000000 00:00 0
7f4f54352000-7f4f54353000 r–p 00000000 00:00 0
7f4f54353000-7f4f54354000 —p 00000000 00:00 0
7f4f54354000-7f4f54355000 r–p 00000000 08:01 1992 /usr/lib/x86_64-linux-gnu/ld-2.28.so
7f4f54355000-7f4f54373000 r-xp 00001000 08:01 1992 /usr/lib/x86_64-linux-gnu/ld-2.28.so
7f4f54373000-7f4f5437b000 r–p 0001f000 08:01 1992 /usr/lib/x86_64-linux-gnu/ld-2.28.so
7f4f5437b000-7f4f5437c000 r–p 00026000 08:01 1992 /usr/lib/x86_64-linux-gnu/ld-2.28.so
7f4f5437c000-7f4f5437d000 rw-p 00027000 08:01 1992 /usr/lib/x86_64-linux-gnu/ld-2.28.so
7f4f5437d000-7f4f5437e000 rw-p 00000000 00:00 0
7ffcbda03000-7ffcbda24000 rw-p 00000000 00:00 0 [stack]
7ffcbdb65000-7ffcbdb68000 r–p 00000000 00:00 0 [vvar]
7ffcbdb68000-7ffcbdb6a000 r-xp 00000000 00:00 0 [vdso]
VM Arguments:
jvm_args: -Xms10G -Xmx29G -Dterminal.jline=false -Dterminal.ansi=true
java_command: paper-1.17.1-308.jar
java_class_path (initial): paper-1.17.1-308.jar
Launcher Type: SUN_STANDARD
[Global flags]
intx CICompilerCount = 4 {product} {ergonomic}
uint ConcGCThreads = 2 {product} {ergonomic}
uint G1ConcRefinementThreads = 8 {product} {ergonomic}
size_t G1HeapRegionSize = 16777216 {product} {ergonomic}
uintx GCDrainStackTargetSize = 64 {product} {ergonomic}
size_t InitialHeapSize = 10737418240 {product} {command line}
size_t MarkStackSize = 4194304 {product} {ergonomic}
size_t MaxHeapSize = 31138512896 {product} {command line}
size_t MinHeapDeltaBytes = 16777216 {product} {ergonomic}
size_t MinHeapSize = 10737418240 {product} {command line}
uintx NonNMethodCodeHeapSize = 5839372 {pd product} {ergonomic}
uintx NonProfiledCodeHeapSize = 122909434 {pd product} {ergonomic}
uintx ProfiledCodeHeapSize = 122909434 {pd product} {ergonomic}
uintx ReservedCodeCacheSize = 251658240 {pd product} {ergonomic}
bool SegmentedCodeCache = true {product} {ergonomic}
size_t SoftMaxHeapSize = 31138512896 {manageable} {ergonomic}
bool UseCompressedClassPointers = true {product lp64_product} {ergonomic}
bool UseCompressedOops = true {product lp64_product} {ergonomic}
bool UseG1GC = true {product} {ergonomic}
Logging:
Log output configuration:
#0: stdout all=warning uptime,level,tags
#1: stderr all=off uptime,level,tags
Environment Variables:
JAVA_HOME=/usr/lib/jvm/jdk-17/
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/lib/jvm/jdk-17//bin
SHELL=/bin/bash
LANG=en_US.UTF-8
Signal Handlers:
SIGSEGV: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
SIGBUS: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
SIGFPE: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
SIGPIPE: javaSignalHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
SIGXFSZ: javaSignalHandler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
SIGILL: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
SIGUSR2: SR_handler in libjvm.so, mask=00000000000000000000000000000000, flags=SA_RESTART|SA_SIGINFO
SIGHUP: SIG_DFL, mask=00000000000000000000000000000000, flags=none
SIGINT: SIG_DFL, mask=00000000000000000000000000000000, flags=none
SIGTERM: SIG_DFL, mask=00000000000000000000000000000000, flags=none
SIGQUIT: SIG_DFL, mask=00000000000000000000000000000000, flags=none
SIGTRAP: crash_handler in libjvm.so, mask=11100100010111111101111111111110, flags=SA_RESTART|SA_SIGINFO
--------------- S Y S T E M ---------------
OS:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
uname: Linux 4.19.0-17-cloud-amd64 #1 SMP Debian 4.19.194-3 (2021-07-18) x86_64
OS uptime: 1 days 3:11 hours
libc: glibc 2.28 NPTL 2.28
rlimit (soft/hard): STACK 8192k/infinity , CORE 0k/infinity , NPROC 125596/125596 , NOFILE 1048576/1048576 , AS infinity/infinity , CPU infinity/infinity , DATA infinity/infinity , FSIZE infinity/infinity , MEMLOCK 65536k/65536k
load average: 0.31 0.34 0.36
/proc/meminfo:
MemTotal: 32169988 kB
MemFree: 540128 kB
MemAvailable: 912616 kB
Buffers: 41712 kB
Cached: 680208 kB
SwapCached: 0 kB
Active: 30959480 kB
Inactive: 363800 kB
Active(anon): 30601492 kB
Inactive(anon): 16628 kB
Active(file): 357988 kB
Inactive(file): 347172 kB
Unevictable: 0 kB
Mlocked: 0 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 7936 kB
Writeback: 0 kB
AnonPages: 30601460 kB
Mapped: 56860 kB
Shmem: 16760 kB
Slab: 159012 kB
SReclaimable: 56932 kB
SUnreclaim: 102080 kB
KernelStack: 4624 kB
PageTables: 62252 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 16084992 kB
Committed_AS: 11583372 kB
VmallocTotal: 34359738367 kB
VmallocUsed: 0 kB
VmallocChunk: 0 kB
Percpu: 2848 kB
AnonHugePages: 14704640 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
DirectMap4k: 218992 kB
DirectMap2M: 32548864 kB
/sys/kernel/mm/transparent_hugepage/enabled: [always] madvise never
/sys/kernel/mm/transparent_hugepage/defrag (defrag/compaction efforts parameter): always defer defer+madvise [madvise] never
Process Memory:
Virtual Size: 21768648K (peak: 32250644K)
Resident Set Size: 18156K (peak: 18156K) (anon: 6528K, file: 11628K, shmem: 0K)
Swapped out: 0K
C-Heap outstanding allocations: 752K
/proc/sys/kernel/threads-max (system-wide limit on the number of threads): 251193
/proc/sys/vm/max_map_count (maximum number of memory map areas a process may have): 65530
/proc/sys/kernel/pid_max (system-wide limit on number of process identifiers): 32768
container (cgroup) information:
container_type: cgroupv1
cpu_cpuset_cpus: 0-7
cpu_memory_nodes: 0
active_processor_count: 8
cpu_quota: no quota
cpu_period: 100000
cpu_shares: no shares
memory_limit_in_bytes: unlimited
memory_and_swap_limit_in_bytes: not supported
memory_soft_limit_in_bytes: unlimited
memory_usage_in_bytes: 32082190336
memory_max_usage_in_bytes: 32549797888
KVM virtualization detected
Steal ticks since vm start: 0
Steal ticks percentage since vm start: 0.000
CPU: total 8 (initial active 8) (1 cores per cpu, 1 threads per core) family 6 model 60 stepping 1 microcode 0x1, cx8, cmov, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, lzcnt, tsc, avx, avx2, aes, erms, clmul, bmi1, bmi2, fma, vzeroupper, clflush, hv
CPU Model and flags from /proc/cpuinfo:
model name : Intel Core Processor (Haswell, no TSX)
flags : fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 syscall nx rdtscp lm constant_tsc rep_good nopl xtopology cpuid tsc_known_freq pni pclmulqdq vmx ssse3 fma cx16 pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm cpuid_fault invpcid_single pti tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase bmi1 avx2 smep bmi2 erms invpcid xsaveopt arat
Online cpus: 0-7
Offline cpus:
BIOS frequency limitation:
Frequency switch latency (ns):
Available cpu frequencies:
Current governor:
Core performance/turbo boost:
Memory: 4k page, physical 32169988k(540128k free), swap 0k(0k free)
Page Sizes: 4k
vm_info: Java HotSpot™ 64-Bit Server VM (17+35-LTS-2724) for linux-amd64 JRE (17+35-LTS-2724), built on Aug 5 2021 22:21:00 by "mach5one" with gcc 10.3.0
END.
Voici également le top -o RES
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
5215 root 20 0 56.6g 29.7g 31240 S 27.2 96.9 245:46.00 java
et après le crash
5215 root 20 0 56.6g 29.7g 31240 S 31.2 14.9 245:46.00 java
et pendant le crash
5215 root 20 0 56.6g 29.7g 31240 S 531.2 1.3 245:46.00 java
et ensuite petit à petit la %MEM augment tandis que %CPU dminue jusqu'à se que ça crash à nouveau
in-com-pré-hen-SIBLE !
Si une personne à une solution qu'il vienne m'aider car la je suis à bout de force…
simple : vous attribuer trop de RAM à votre JAVA (ce qui semble enclencher le "OOM Killer" oou une protection dans JAVA).
Dégager l'option -Xms10G et pour l'option -Xmx ne pas dépasser 28G (ce qui fait +/- 85% de la RAM car visiblement il y a 32Go).
Note : mettez tout ça dans une balise code, pour que ce soit moins "agressif" au niveau visuel.
Merci beaucoup de la réponse
Dégager = enlever ?
Etes vous sûr à 100% de ce que vous dites ?
Je dit cela car beaucoup de personne m'on dit plein de chose (méthode) qui ne marchait pas.
Dégager = enlever ?
oui
sur quel partie ?
Sur: Dégager l'option -Xms10G et pour l'option -Xmx ne pas dépasser 28G (ce qui fait +/- 85% de la RAM car visiblement il y a 32Go).
C'est une solution qui va régler mon problème à cout sûr ?
cela va au minimum permettre de le démarrer, par contre vous allez avoir un problème à court terme car d'après les données que vous montrez le VPS n'a pas beaucoup de RAM de dispo (vu qu'il arrive même pas à attribuer 10Go).
Donc sans avoir l'intégralité des informations, oui cela va permettre de lancer le programme mais il va crash dès que la demande mémoire sera trop importante.
Le "programme" qui est un serveur de jeu ce lance comme il faut seulement il crash tout seul avec ce message d'erreur
Le serveur est capable de rester ouvert sans crasher pendant des heures. Mais pas une journée
j'ai 32Go de ram et 320 de stockage SSD
avec le serveur éteint, que donne un free -mh
Désolé mais je ne peux pas effectuer cette commande car je suis en ce moment même entrain de réinstaller mon serveur avec pterodactyl.
J'ai maintenant écris la commande.
root@vps-f61310e3:~# free -mh
------------total----used-----free----shared–buff/cache–available
Mem:----30Gi---- 4.7Gi----21Gi----34Mi----4.6Gi----------25Gi
Swap: 0B 0B 0B
Je tiens à dire que ce qui cause le crash est le faite que m'a ram est en constante expansion de consommation. Jusqu'à le timeout, puis je redémarre et ça recommence
il faut regarder au moment voulu ce qui consomme la RAM (via htop par exemple).
Qu'elle est la commande pour regarder ?
Vous parler du top -o RES ?
Car ce qui consomme de la mémoire c'est java je le vois bien mais pourquoi il en consomme autant ?
Ce qui consomme de la mémoire c'est java je le vois bien mais pourquoi il en consomme autant ?
il n'y a pas de message d'erreur dans la console tout semble fonctionné sauf qu'en arrière plan toute m'a ram ce consomme.
parce que vous lui avez donné pour consigne de consommer la maximum de la RAM ?
Non sauf si il le fait tout seul.
d'après les commande que vous avez posté au début : non vous lui spécifiez bien quoi consommer.
Dans ce cas bien précis je partirai déjà sur le fait de lancer le programme JAVA avec uniquement cet argument "-Xmx20G" et voir le comportement sur plusieurs heures/jours.
La consommation de RAM de JAVA devrais augmenter avec l'utilisation mais pas dépasser 20Go et si vraiment le programme a besoin de plus de 20Go ça va crash
Je confirme le programme à besoin de plus de 20Go.
