Multiple IPs wont work inside a proxmox vm
Hi there,
I hope someone can help me with this because it's driving me crazy.
I have 3 ips I wanna use on a Proxmox VM. I've assigned 3 interfaces to it and setup the macaddresses from OVH panel to each interface for the IPs.
I'm running Ubuntu 18.04 server. I'm using netplan to setup the ips, but whatever I do, I can only get one of the IP working. if I comment the other interfaces, I can get all of the IP working, but only one at a time. I need some serious help in what is suppose to go into the netplan config.
Proxmox IP: 51.178.68.146
My virtual machines IP I wanna configure:
5.196.33.108 (ens18) (mac: 02:00:00:d0:f5:01)
37.59.82.61 (ens21) (mac: 02:00:00:aa:6b:03)
37.59.82.62 (ens22) (mac: 02:00:00:32:24:39)
the last two are on it's own block while the first is on another block.
My netplan with one working at a time looks like this:
network:
version: 2
renderer: networkd
ethernets:
ens18:
addresses: 5.196.33.108/24 ]
gateway4: 5.196.33.254
nameservers:
addresses: [ 8.8.8.8,8.8.4.4 ]
search:
ens19:
addresses: [ 192.168.1.10/24 ]
ens20:
addresses: [ 192.168.100.10/24 ]
ens21:
addresses: [ 37.59.82.61/24 ]
gateway4: 37.59.82.61.254
nameservers:
addresses:
- "8.8.8.8"
- "8.8.4.4"
ens22:
addresses: [ 37.59.82.62/24 ]
gateway4: 37.59.82.62.254
nameservers:
addresses:
- "8.8.8.8"
- "8.8.4.4"
Any help would be appreciated, because I've tried it all, and I really can't get it working.
Here's an image to the ip setup on OVH panel:
![ipsetup|690x248
