MXPLAN 100 (in PRO Hosting offer) to MX5
Hello,
I have the "Pro" web hosting for the domain spiritofmanga.com (service reference 48674945), with the mail service "MXPLAN 100" currently included in this hosting (service reference 48675711).
This mail service contains three active mailboxes: cde, postmaster, contact.
I no longer use the web hosting itself at all (the website is hosted elsewhere), only the three mailboxes. I would therefore like to:
  1. Migrate my mail service to a standalone MX Plan (independent of the hosting), keeping the current contents of the three mailboxes and without any interruption of mail reception.
  2. Once this migration is confirmed and functional, cancel the now‑unnecessary Pro web hosting.
Could you confirm the procedure to follow to perform this migration properly, without data loss or mail service interruption?
Thank you in advance.
Hello,
The procedure recommended by OVH is to detach (unlink) your MX Plan from your web hosting (via your client area in the Hosting section).
This results in a one‑time payment. The catch is that I don’t know whether you could qualify for an MX5 or MX25, which would better match your needs...
Hello @SamuelC6,
Here you have two options:
The first, mentioned by @fritz2cat: Unlink
Step 1 of 2: Go to the general information of your web hosting,
Step 2 of 2: Click the three dots next to “mail address”, then “unlink the mail offer”,
You will then be able to purchase an MX Plan Full instead of an MXplan 5.
The second option: Delete and purchase an MXplan 5 offer
Step 1 of 3: Go to the general information of your web hosting,
Step 2 of 3: Click the three dots next to “mail address”, then “cancel mail offer”,
Step 3 of 3: An email will be sent to you; you will need to confirm it to finalize the cancellation, then you just have to contact support and let them know you want to speed up the deletion process so that we can delete it permanently.
Once this offer is deleted, you will be able to purchase a new MXplan 5.
Note that deleting this offer will also delete the mailboxes and their contents. If necessary, you can back up using this guide: https://help.ovhcloud.com/csm/fr-mx-plan-migrate-email-addresses-manually?id=kb_article_view&sysparm_article=KB0052185#exporter_1
If you want to proceed with the second option, you will need to go through support, so feel free to open a support ticket and give me the number so I can proceed :wink:
Asterix
It occurs to me to first change your Pro hosting to Personal. This should be possible if your allocated resources do not exceed the limits of Personal (disk space, number and size of databases, number of mailboxes).
Then detach the mail hosting, which could be an MX25.
