Domain name does not appear in hosting
Hello,
I'm trying to install my website with a “one‑click module” (CMS). I got my domain name from OVH and I'm following the instructions on this page https://docs.ovhcloud.com/fr/guides/web-cloud/web-hosting/cms-install-1-click-modules, but my domain name doesn't appear in my hosting...
I really have no idea, thank you for your help :sweat_smile:
Hello @TerresD
Which domain?
If it’s a “one‑click” installation, the cleanest approach is to uninstall everything and install WordPress manually and properly.
See the paragraph in my guide: X5 - Deleting a site installed “one‑click”
Here is a short guide I wrote that could give you clarification for a complete and clean installation of your site.
Guide – Understanding the Relationship Domain > DNS Zone > Hosting > Site folder
See --> CMS – WordPress – Installation Guide at OVH
Read and check your situation by following carefully the sections: A to J valid for all CMSs
Feel free to give me feedback: positive or negative.
That’s how I fine‑tune my guide.
If my answer is the solution, please click “Approve the solution”.
Hello @Terr​esD,
To link your internal domain name to your OVHcloud hosting, follow these steps:
Step 1 of 5: Click on your hosting under the "Hosting" section and go to the "Multisite" tab,
Step 2 of 5: Click "Action" then "Add a domain",
Step 3 of 5: Select your domain name from the list and click next,
Step 4 of 5: Fill in the fields with the values below:
   • Subdomain:
   • Root folder: www
   • Check the box to also create the "www" subdomain.
Step 5 of 5: Click "Next" then "Validate".
A DNS propagation delay is required for these changes to take effect; this delay varies from 4 to 24 hours.
Is your issue resolved?
Astérix
