OVH Billing System Down
https://www.ovh.ie/cgi-bin/order/renew.cgi
Error 504: Backend unavailable
This type of error results generally from the client server, used as a backend.
If you are a visitor of the website, please try to refresh it or come back in a few minutes.
If you are the administrator of the website, please check the configuration of your server and/or CDN rules.
In case the problem persists, please contact us.
https://www.status-ovhcloud.com/
The same issue since 15.09.26
I had similar issues in the past but during couple days they were fixed.
I opened a ticket, but still no response.
