IPv6 is great when you deploy virtual machines on a host, or at home when you self‑host certain services (different subnet, dedicated IP per VM, etc.). The fact that each VM can easily have its own public IP is really awesome.
Otherwise, yes, I feel that OVH’s IPv6 is a bit flaky at times...
I’d seen this draft; there are many, but I don’t think IPv6 will be abandoned.
Personally, I don’t use IPv6 as long as OVH doesn’t allow moving them off a server/instance.
You need to get a /64 on the vRack, and in that case you can allocate your IPv6 to different servers. But vRack is mandatory in this scenario, which isn’t compatible with VPS.
You’re absolutely right—if a provider promotes a technology, it’s logical to expect them to use it themselves. However, the reality for large service providers is that migrating a complex infrastructure, such as the web and support systems, is a process that’s done in phases and with care.
They prioritize stability for their customers (usually ), so sometimes their own ‘showcase’ is updated at the end of the process.
Hi.
This noon also (13:29 Paris) IPv6 packets are not passing AS16276 :
$ sudo traceroute6 -n gitlab.com traceroute to gitlab.com (2606:4700:90:0:f22e:fbec:5bed:a9b9), 30 hops max, 80 byte packets 1 2001:41d0:302:1100::1 1.295 ms 1.206 ms 1.156 ms 2 fd00::ffe 1.674 ms 1.623 ms 1.574 ms 3 2001:41d0:0:1:3::aabf 2.577 ms 2.524 ms 2.478 ms 4 2001:41d0:0:1:3::aac0 2.427 ms 2.381 ms 2001:41d0:0:1:3::a73e 2.332 ms 5 * * *
$ sudo traceroute6 -n ipv6.google.com traceroute to ipv6.google.com (2a00:1450:4007:809::200e), 30 hops max, 80 byte packets 1 2001:41d0:302:1100::1 0.480 ms 0.422 ms 0.384 ms 2 fd00::ffe 0.353 ms 1.099 ms 1.060 ms 3 2001:41d0:0:1:3::aabf 1.030 ms 0.999 ms 0.969 ms 4 2001:41d0:0:1:3::aac0 0.938 ms 0.898 ms 2001:41d0:0:1:3::a73e 0.856 ms 5 2001:41d0:0:1:3::a13e 1.350 ms * * 6 * * *
