php code is not being executed
I just created an subfolder and installed a Joomla instance, now the PHP code is not being executed, but the code shows in the browser source code - any suggestion???
Thanks for your help
Hi @ClaudeF
Which PHP version?
Instead of creating a subfolder in /www and installing Joomla there, create a /joomla folder at the same level as /www.
See my guide : CMS - Wordpress - Ajouter un deuxième domaine - Une 2ème installation de site sur un même hébergement
Hello,
Please check for a presence of a file names .htaccess in that subfolder. If there is one, can you post here its contents ?
Are your PHP files uploaded with a filename ending in ".php" in lowercase ?
Maybe the .htaccess file was the issue, but I went for a more radical solution—I deleted the entire subdirectory. Problem solved!
