Problème AH10149: FastCGI: incomplete headers (0 bytes)
Bonjour tout le monde,
J'ai un site web : webat-renov.fr
J'ai l'hebergement mutalisés avec : webatry.cluster027.hosting.ovh.net
J'utilise wordpress pour developper mon site et j'ai des erreur 505 qui arrive sur mon site
"Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at postmaster@webat-renov.fr to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log."
quand je vais regarder les logs d'erreur sur OVH j'ai
Sat Aug 19 12:44:17 2023] [error] [client 2a01:cb09:b05c:4510:c19] [host webat-renov.fr] (104)Connection reset by peer: AH10143: FastCGI: comm with server "/homez.256/webatry/www/wp-admin/admin-ajax.php" aborted: read failed, referer: https://webat-renov.fr/wp-admin/post.php?post=1560&action=edit
[Sat Aug 19 12:44:17 2023] [error] [client 2a01:cb09:b05] [host webat-renov.fr] AH10149: FastCGI: incomplete headers (0 bytes) received from server "/homez.256/webatry/www/wp-admin/admin-ajax.php", referer: https://webat-renov.fr/wp-admin/post.php?post=1560&action=edit
[Sat Aug 19 12:44:17 2023] [error] [client 2a01:cb09:b05c:] [host webat-renov.fr] AH10157: FastCGI: An error happened during Fastcgi processing, fallback to CGI, referer: https://webat-renov.fr/wp-admin/post.php?post=1560&action=edit
[Sat Aug 19 12:44:18 2023] [error] [client 2a01:cb09] [host webat-renov.fr] (104)Connection reset by peer: AH10143: FastCGI: comm with server "/homez.256/webatry/www/index.php" aborted: read failed, referer: https://webat-renov.fr/wp-admin/customize.php?url=https%3A%2F%2Fwebat-renov.fr%2Fles-articles%2F
[Sat Aug 19 12:44:18 2023] [error] [client 2a01:cb] [host webat-renov.fr] AH10149: FastCGI: incomplete headers (0 bytes) received from server "/homez.256/webatry/www/index.php", referer: https://webat-renov.fr/wp-admin/customize.php?url=https%3A%2F%2Fwebat-renov.fr%2Fles-articles%2F
J'avais fait une installe en 1 click quand j'avais déjà le problème j'ai du coup refais une installation en suivant le guide manuelle mais le problème est toujours à
Pouvez vous m'aider ?
Bonjour @8a5d6bf9615ce7f827b5
https://webat-renov.fr –> Bon
J'avais fait une installe en 1 click quand j'avais déjà le problème j'ai du coup refais une installation en suivant le guide manuelle mais le problème est toujours là
Quel guide ? Quel lien ?
Avez-vous un exemple de lien montrant votre problème ?
Aucun lien ne fonctionne :
Je n'ai pas de lien car le problème arrive sur wordpress directement qui m'émèche parfois de publier des nouvelles pages ou même d'arriver au back office tout cours avec des erreur 500 server .
Quand je check mon log coté OVH je vois les erreur de log que j'ai attaché a mon premier message
Combien de plugins utilisez-vous et quels sont-ils ?
Quel guide avez-vous suivi ?
Quelle version de PHP ?
à dans 17 jours. :slight_smile:
J&#39;utilise <br />- Theme : Blocksy PRO <br />- Builder : Elementor PRO <br />&#43; : <br />EWWW Image Optimizer<br />Health Check &amp; Troubleshooting<br />UpdraftPlus - Sauvegarde/Restauration<br />WooCommerce<br />WooCommerce Google Analytics Integration<br />Wordfence Security<br />WP Rocket<br />Yoast SEO<br /><br />J&#39;ai suivi l&#39;installation - &gt; CMS - WordPress - Guide Installation chez OVH- <br />Le problème dans mes logs est revenue assez rapidement sur le site. <br /><br />PHP version 8.1 <br /><br />Toutes mes plug ins sont mis a jour. <br /><br />Mon HTA file est <br />&#34;&#96;RewriteEngine On<br /><br />  ## www -&gt; no-www<br />RewriteCond %{HTTP_HOST} ^www\.(.&#43;)$ <br />RewriteRule ^ https://%1%{REQUEST_URI} [R&#61;301,L,NE,QSA]<br /><br />  ## http -&gt; https<br />RewriteCond %{HTTP:X-Forwarded-Proto} !https<br />RewriteCond %{HTTPS} off<br />RewriteRule ^ https://%{HTTP_HOST}%{REQUEST_URI} [R&#61;301,L,NE,QSA]<br /><br /># BEGIN WordPress<br /><br />Header always set Strict-Transport-Security &#34;max-age&#61;31536000; includeSubDomains; preload&#34;<br />RewriteEngine On<br />RewriteBase /<br />RewriteRule ^index\.php$ - [L]<br />RewriteCond %{REQUEST_FILENAME} !-f<br />RewriteCond %{REQUEST_FILENAME} !-d<br />RewriteRule . /index.php [L]<br /><br /># END WordPress&#96;<br /><br />qui est localiser à la racine home/nom_de_mon_répertoire <br />avec ma file ovh config <br /><br />J&#39;ai un autre fichier hta sous home/nom_de_mon_répertoire/www<br />qui a <br />&#34;# BEGIN WP Rocket v3.14.4.2<br /># Use UTF-8 encoding for anything served text/plain or text/html<br />AddDefaultCharset UTF-8<br /># Force UTF-8 for a number of file formats<br /><br />AddCharset UTF-8 .atom .css .js .json .rss .vtt .xml<br /><br /><br /># FileETag None is not enough for every server.<br /><br />Header unset ETag<br /><br /><br /># Since we’re sending far-future expires, we don’t need ETags for static content.<br /># developer.yahoo.com/performance/rules.html#etags<br />FileETag None<br /><br /><br /><br /><br />Header set X-Powered-By &#34;WP Rocket/3.14.4.2&#34;<br />Header unset Pragma<br />Header append Cache-Control &#34;public&#34;<br />Header unset Last-Modified<br /><br /><br /><br /><br /><br />Header unset Pragma<br />Header append Cache-Control &#34;public&#34;<br /><br /><br /><br /><br /><br />	AddType image/avif                                  avif<br />    AddType image/avif-sequence                         avifs<br /><br /># Expires headers (for better cache control)<br /><br />	ExpiresActive on<br />	ExpiresDefault                              &#34;access plus 1 month&#34;<br />	# cache.appcache needs re-requests in FF 3.6 (thanks Remy ~Introducing HTML5)<br />	ExpiresByType text/cache-manifest           &#34;access plus 0 seconds&#34;<br />	# Your document html<br />	ExpiresByType text/html                     &#34;access plus 0 seconds&#34;<br />	# Data<br />	ExpiresByType text/xml                      &#34;access plus 0 seconds&#34;<br />	ExpiresByType application/xml               &#34;access plus 0 seconds&#34;<br />	ExpiresByType application/json              &#34;access plus 0 seconds&#34;<br />	# Feed<br />	ExpiresByType application/rss&#43;xml           &#34;access plus 1 hour&#34;<br />	ExpiresByType application/atom&#43;xml          &#34;access plus 1 hour&#34;<br />	# Favicon (cannot be renamed)<br />	ExpiresByType image/x-icon                  &#34;access plus 1 week&#34;<br />	# Media: images, video, audio<br />	ExpiresByType image/gif                     &#34;access plus 4 months&#34;<br />	ExpiresByType image/png                     &#34;access plus 4 months&#34;<br />	ExpiresByType image/jpeg                    &#34;access plus 4 months&#34;<br />	ExpiresByType image/webp                    &#34;access plus 4 months&#34;<br />	ExpiresByType video/ogg                     &#34;access plus 4 months&#34;<br />	ExpiresByType audio/ogg                     &#34;access plus 4 months&#34;<br />	ExpiresByType video/mp4                     &#34;access plus 4 months&#34;<br />	ExpiresByType video/webm                    &#34;access plus 4 months&#34;<br />	ExpiresByType image/avif                    &#34;access plus 4 months&#34;<br />	ExpiresByType image/avif-sequence           &#34;access plus 4 months&#34;<br />	# HTC files  (css3pie)<br />	ExpiresByType text/x-component              &#34;access plus 1 month&#34;<br />	# Webfonts<br />	ExpiresByType font/ttf                      &#34;access plus 4 months&#34;<br />	ExpiresByType font/otf                      &#34;access plus 4 months&#34;<br />	ExpiresByType font/woff                     &#34;access plus 4 months&#34;<br />	ExpiresByType font/woff2                    &#34;access plus 4 months&#34;<br />	ExpiresByType image/svg&#43;xml                 &#34;access plus 4 months&#34;<br />	ExpiresByType application/vnd.ms-fontobject &#34;access plus 1 month&#34;<br />	# CSS and JavaScript<br />	ExpiresByType text/css                      &#34;access plus 1 year&#34;<br />	ExpiresByType application/javascript        &#34;access plus 1 year&#34;<br /><br /># Gzip compression<br /><br /># Active compression<br />SetOutputFilter DEFLATE<br /># Force deflate for mangled headers<br /><br /><br />SetEnvIfNoCase ^(Accept-EncodXng|X-cept-Encoding|X{15}|~{15}|-{15})$ ^((gzip|deflate)\s*,?\s*)&#43;|[X~-]{4,13}$ HAVE_Accept-Encoding<br />RequestHeader append Accept-Encoding &#34;gzip,deflate&#34; env&#61;HAVE_Accept-Encoding<br /># Don’t compress images and other uncompressible content<br />SetEnvIfNoCase Request_URI \<br />\.(?:gif|jpe?g|png|rar|zip|exe|flv|mov|wma|mp3|avi|swf|mp?g|mp4|webm|webp|pdf)$ no-gzip dont-vary<br /><br /><br /><br /># Compress all output labeled with one of the following MIME-types<br /><br />AddOutputFilterByType DEFLATE application/atom&#43;xml \<br />		                          application/javascript \<br />		                          application/json \<br />		                          application/rss&#43;xml \<br />		                          application/vnd.ms-fontobject \<br />		                          application/x-font-ttf \<br />		                          application/xhtml&#43;xml \<br />		                          application/xml \<br />		                          font/opentype \<br />		                          image/svg&#43;xml \<br />		                          image/x-icon \<br />		                          text/css \<br />		                          text/html \<br />		                          text/plain \<br />		                          text/x-component \<br />		                          text/xml<br /><br /><br />Header append Vary: Accept-Encoding<br /><br /><br /><br /># END WP Rocket<br /><br /># BEGIN LSCACHE<br /># END LSCACHE<br /># BEGIN NON_LSCACHE<br /># END NON_LSCACHE<br /># BEGIN WordPress<br /># Les directives (lignes) entre « BEGIN WordPress » et « END WordPress » sont générées<br /># dynamiquement, et doivent être modifiées uniquement via les filtres WordPress.<br /># Toute modification des directives situées entre ces marqueurs sera surchargée.<br /><br />RewriteEngine On<br />RewriteRule .* - [E&#61;HTTP_AUTHORIZATION:%{HTTP:Authorization}]<br />RewriteBase /<br />RewriteRule ^index\.php$ - [L]<br />RewriteCond %{REQUEST_FILENAME} !-f<br />RewriteCond %{REQUEST_FILENAME} !-d<br />RewriteRule . /index.php [L]<br /><br /><br /># END WordPress<br /><br /><br /># Wordfence WAF<br /><br /><br />	Require all denied<br /><br /><br />	Order deny,allow<br />	Deny from all<br /><br /><br /><br /># END Wordfence WAF<br /><br /># BEGIN EWWWIO<br /># Les directives (lignes) entre « BEGIN EWWWIO » et « END EWWWIO » sont générées<br /># dynamiquement, et doivent être modifiées uniquement via les filtres WordPress.<br /># Toute modification des directives situées entre ces marqueurs sera surchargée.<br /><br />RewriteEngine On<br />RewriteCond %{HTTP_ACCEPT} image/webp<br />RewriteCond %{REQUEST_FILENAME} (.*)\.(jpe?g|png|gif)$<br />RewriteCond %{REQUEST_FILENAME}.webp -f<br />RewriteCond %{QUERY_STRING} !type&#61;original<br />RewriteRule (.&#43;)\.(jpe?g|png|gif)$ %{REQUEST_URI}.webp [T&#61;image/webp,L]<br /><br /><br /><br />Header append Vary Accept<br /><br /><br />AddType image/webp .webp<br /># END EWWWIO&#34;
Qu'est-ce que c'est que ces deux fichiers .htaccess ?
Il en faut un seul qui doit se trouver au niveau des trois dossiers wp_xxx
D'autre part qu'est-ce que c'est que ce fichier à rallonge et à compression ?
Bonjour @8a5d6bf9615ce7f827b5,
Avez-vous pu trouver une solution depuis votre dernier message ?
Si ce n’est pas le cas, je vous invite à ajouter des éléments afin qu’un nouveau retour puisse vous être apporté par la communauté.
^FabL
