Hello,
I just installed a WordPress site with a premium Overlay theme from Kairaweb;
I installed Elementor and, after trying all caches, I'm having display issues with Elementor's preview;
It works the same without cache as it does with LiteSpeed, W3, Fastest Cache, and the others;
It seems that OVH is running on Apache;
Do you have a cache plugin to recommend for my site?
Thanks
I gave you my answer here:
Hello @sturpin
Um! I don’t see your reply
Thank you
Now it seems to me that there is a problem between php 8.5 and Elementor;
I'm checking if there is a thread about this
Thank you
