Mon nom de domaine est : philippinewiart.fr
Et j'utilise l'offre : MXPLAN 1 hosting
Depuis quelques temps, je reçois un email me disant que ma boite mail est bientôt pleine alors qu'en réalité, je suis loin d'avoir utilisé les 5GO de mon offre.
Ci-dessous des screenshots.
Depuis hier, les personnes souhaitant m'envoyer un email reçoivent le mail d'erreur suivant de MAILER-DAEMON@mx1.ovh.net, et je ne reçois plus aucun email. Ci-dessous le screenshot et la copie du message d'erreur.
Comment faire pour résoudre rapidement ce problème ?
Un grand merci pour votre aide.
Bonne journée,
Philippine
Vous
Ven 08/03/2024 07:19
Hi. This is the qmail-send program at mx1.ovh.net.
I'm afraid I wasn't able to deliver your message to the following addresses.
This is a permanent error; I've given up. Sorry it didn't work out.
user is over quota
— Below this line is a copy of the message.
Return-Path:
Received: from localhost (HELO queue) (127.0.0.1)
by localhost with SMTP; 8 Mar 2024 08:19:12 +0200
Received: from unknown (HELO output52.mail.ovh.net) (192.168.13.69)
by 192.168.9.16 with AES256-GCM-SHA384 encrypted SMTP; 8 Mar 2024 08:19:12 +0200
Received: from vr35.mail.ovh.net (unknown [10.101.8.35])
by out52.mail.ovh.net (Postfix) with ESMTP id 4Trbbh4wtczYp3FDG
for ; Fri, 8 Mar 2024 06:19:12 +0000 (UTC)
Received: from in59.mail.ovh.net (unknown [10.101.4.59])
by vr35.mail.ovh.net (Postfix) with ESMTP id 4Trbbh3PQ6z3vkrkp
Received-SPF: Pass (mailfrom) identity=mailfrom; client-ip=40.92.75.96; helo=eur04-vi1-obe.outbound.protection.outlook.com; envelope-from=philippine.wiart@outlook.com; receiver=contact@philippinewiart.fr
Authentication-Results: in59.mail.ovh.net;
dkim=pass (2048-bit key; unprotected) header.d=outlook.com header.i=@outlook.com header.b="Qb6r4sJC";
dkim-atps=neutral
Received: from EUR04-VI1-obe.outbound.protection.outlook.com (mail-vi1eur04olkn2096.outbound.protection.outlook.com [40.92.75.96])
by in59.mail.ovh.net (Postfix) with ESMTPS id 4Trbbh1pDDz2cLXRS
for ; Fri, 8 Mar 2024 06:19:11 +0000 (UTC)
ARC-Seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none;
b=ZNrFuj2kC4wUHvUKm+2KLJISnDOF/IqIA7zvzVxdG4lJmDS3MMrX2A1aayT+regJMGNbrFkK3Q+sJwzMtPb35tHNu99jEHILNcwsTsj2xaSW5Ayi3VtfYCORFgZt5cCUXdtT4Npwx4Gudk1FtcawUL8JNZ/IyHoM+w3dCjQKUYRnID3laAx4mgLvCE3PShCxCFFypOrTYEsoSZzWXWEy1KdvYNLzI2z0+SzwtBj+879YqmVg8jBGT9HUlrtccLIUpbJQrL1XunuTUJaUZyt+CWksgU1v9anedBKJjSlaftHSqT8b5bYL1QYStm5HZ0+gqD+FirJmulhKAKD9as3fFQ==
ARC-Message-Signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com;
s=arcselector9901;
h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-AntiSpam-MessageData-ChunkCount:X-MS-Exchange-AntiSpam-MessageData-0:X-MS-Exchange-AntiSpam-MessageData-1;
bh=47DEQpj8HBSa+/TImW+5JCeuQeRkm5NMpJWZG3hSuFU=;
b=TP6gCXTSAOQiOF7pFLvEVtDdi3A0cSUHr1bf4HjINwppLcqLQ0skEtzyFgwP0fn76en84rNEoGNlIwa0bKyt8IETKtZaO1Zg5fQz+vMEbxbXwoHFhcnALz32UVsgk131Jm5PO4+yDg8VyFQ+DXxunR2Ij8CS67FsQZxjPFAY7UbTEskgVXywR375FyqeB6lV9gyc2JXgr+FnKNErG+Ltznn33sBLssj6nfA2EBubtOwvljOXtcqb7APMblDCAO/FnaeUvf5Q8YLiSfMJ3PVI8xCEirJ5gbHbTYLidh1q2EY2xw/BXa0346/l6LFPOQdfGsyLQbUfk5yLisURs/CBpg==
ARC-Authentication-Results: i=1; mx.microsoft.com 1; spf=none; dmarc=none;
dkim=none; arc=none
DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=outlook.com;
s=selector1;
h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck;
b=Qb6r4sJCw6cjQeh70NSQMXtVWPQjM5B+wWazQtww29AtouJJmgJFCoMagDvHjKeyVjcjhcPvcbcQYQQxj3QBZ6Y1ETKhsw8W8bBu9vxiyOARNEeukqR8xr7rIJtBZfb3LV0PzbsR4zUWoGNJ4x9GXGN/kW/DyHKjqlhKvG04Yi/Ll9+O7hGLJT+nT7lkdubiZELMg4bikHP9nNy6VHhsgZ22ye6HoGNp0Er3c9Zk4R65x+Ava2I1WWhbgwwWXAqiGqWyJG/BqZb9yAwob1d8dGChB1smD5bUSsjgFGqK7E0ssFJ6VamBboefhlJTbVJdDJ13fwnZAlXdHW3H+S+5+w==
Received: from PR3P193MB0864.EURP193.PROD.OUTLOOK.COM (2603:10a6:102:ac::23)
by DB9P193MB1291.EURP193.PROD.OUTLOOK.COM (2603:10a6:10:250::14) with
Microsoft SMTP Server (version=TLS1_2,
cipher=TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384) id 15.20.7362.27; Fri, 8 Mar
2024 06:19:10 +0000
([fe80::c915:b506:77ec:7da3]) by PR3P193MB0864.EURP193.PROD.OUTLOOK.COM
([fe80::c915:b506:77ec:7da3%7]) with mapi id 15.20.7339.035; Fri, 8 Mar 2024
06:19:10 +0000
To: Philippine Wiart
Subject: Test
Thread-Topic: Test
Thread-Index: AQHacSCI1f+N4/phW0iTGf8PctI+aA==
Date: Fri, 8 Mar 2024 06:19:10 +0000
Message-ID:
Accept-Language: fr-FR, en-US
Content-Language: fr-FR
X-MS-Has-Attach:
X-MS-TNEF-Correlator:
x-tmn:
[vB4xRPLjGAtTSYBKWXRaoEjGKDuY906bcPZ/vyq5ADvRfVKXQA/Tx0d983TRgw+i24MvD4d/ZWE=]
x-ms-publictraffictype: Email
x-ms-traffictypediagnostic: PR3P193MB0864:EE_|DB9P193MB1291:EE_
x-ms-office365-filtering-correlation-id: 1c7ac429-8e76-47c8-385b-08dc3f37ab34
x-microsoft-antispam: BCL:0;
x-microsoft-antispam-message-info:
hqu1dJ7168RuRH+gFi4N9ygCG374G1cS5051Kn8r+BnAt5KWDDxew1Vz4K2mdXQjqyPu0yhZ1VVnS7iK3mry10GX4GQow5OwLWNt8iaVXY2cxxlMxQBA2j+T3LdIjHwvyYeVs6jyqd0vERxMOqvIcpqoZB+vZHjVGKyuFwDW377LGjCC7KykJb+jm8CIpH5r6kPMQhps5FyKYJ2onBGSIGMSecaY+6pJI+Zrnzui6mrdK8URBnUxwOT9g6IR3DJazI3qZTGWw2K+gwboTf91lP4qb0gZOQr/R/ykD2dzLdM=
x-ms-exchange-antispam-messagedata-chunkcount: 1
x-ms-exchange-antispam-messagedata-0:
=?us-ascii?Q?iI+M+W3Mx4dzhGxOPG4wcZdNmvfUZujvcoRyH4yntRAvy8Ajh8eo7lm7cgQq?=
=?us-ascii?Q?3PCLwZ16KiVSSjLacvvzIjZeOWXs1y0a3hw+2D2e26Q6+EvMs/cb+/wb824l?=
=?us-ascii?Q?4Q7qWVKdgbJg5YIgIXht0skDD9IsZzIbAjsvJ1di/UWON/ZsCUQWmm74+JSi?=
=?us-ascii?Q?3rEyE/dkxQQMPW6BQRFumJLfckYLyifxnHIl7PiGDzEfO2TGZ8aIexLVYLSC?=
=?us-ascii?Q?Ukm2hfk+47KpqB7lmxGvmw/O3yWG0GzdT2xqXrIu7pafy4DSCWvP5CEIDYd8?=
=?us-ascii?Q?lAMngD+3ZGZh7SMNdgUHDfzXONJ5lvnkAtzdeDiscwt8i+G7WV3Bq+PKj6pl?=
=?us-ascii?Q?pxA0/orlMjv6dGhEyQaXCwhYYhOA041Rsi+PzE5txobp81hKCnPDLBhsYdgp?=
=?us-ascii?Q?IoODyQfXueIBq1iYga711dH68s0z2YR7cVD+t3U2rrhgKrgTwFFSZsg3/6fK?=
=?us-ascii?Q?KaKN+VnT2rHxR9YcAVwQGcDYSdW97gbLODrv/y7WyamrJ9iVqRy9Hf/VRkMe?=
=?us-ascii?Q?yZU7HeFUM4sz0H4SOS/7XGCVAkcTlp3uxu9Z+eqdMHUgm0sbAVIcymqiC7S4?=
=?us-ascii?Q?dAciO1gOZucLcXw/ZcxPLp+6V9Z7CdnomEO10ULShfNpXbBmYohAdF6apWmk?=
=?us-ascii?Q?zyx/014Aep4+cLpB+mmAV5l2a0feUImmJf8PkSElHv2/zsG9y3T1IzcmYt9c?=
=?us-ascii?Q?V/dIKx5R+6a0eHLaay6EYxPX3Ai9ybauDA6kFPFTEzta7gi0CTg8CSp59E/k?=
=?us-ascii?Q?GE2Bc0u/X+jaauH0vmSVpqGr43Ftz9CUIV6HM/gHZu+5CuNMkNKqxIJEyRb2?=
=?us-ascii?Q?/2pbr94rRv2ZOvar6LFM6BLhkdu9nM6Sn8adifh3w+DljKCTSQ08bTcGPnVB?=
=?us-ascii?Q?D1y7LUKYHwA8IeYM09bnKMwcsZ7UFwph2koo5ek9V8VSbZgxrqrG5Na/myXD?=
=?us-ascii?Q?lxEFfl1uqwgFbiMW6QtNZq4ymw+cHWMAdJGUK3d6YSBa5K44TqdCKbMhMW4q?=
=?us-ascii?Q?mp+hHml9Te/cgsueW0NlcAAFmehyAzi9W01TffVCO2fyk8V8MgMZlg+svYNm?=
=?us-ascii?Q?UJJqEqwkavV3CtNk2/34IgeMgcVphLZOcoMCU+TWcFtjpGRT2bM5ZjRrJGtp?=
=?us-ascii?Q?hNzW446IlQ8htTblnUQYFvJy88U8r2QjoCTofXN43URMOl2jZSlVmyL+qsWC?=
=?us-ascii?Q?n44lBSLvc9U5E0zAphqgsuwwXIYTA5YympII8il7uPMGE80O5XjQsHAtRMVq?=
=?us-ascii?Q?agf0jHYUc7ad/r24UmaNiNciawpD9F/p6LkqooJhBECS2xlvHO0FGBwneUvT?=
=?us-ascii?Q?uOrZ+j6YVq1Nkbh1cWTEPeqX?=
Content-Type: text/plain; charset="us-ascii"
Content-ID:
Content-Transfer-Encoding: quoted-printable
MIME-Version: 1.0
X-OriginatorOrg: outlook.com
X-MS-Exchange-CrossTenant-AuthAs: Internal
X-MS-Exchange-CrossTenant-AuthSource: PR3P193MB0864.EURP193.PROD.OUTLOOK.COM
X-MS-Exchange-CrossTenant-RMS-PersistedConsumerOrg: 00000000-0000-0000-0000-000000000000
X-MS-Exchange-CrossTenant-Network-Message-Id: 1c7ac429-8e76-47c8-385b-08dc3f37ab34
X-MS-Exchange-CrossTenant-rms-persistedconsumerorg: 00000000-0000-0000-0000-000000000000
X-MS-Exchange-CrossTenant-originalarrivaltime: 08 Mar 2024 06:19:10.7444
(UTC)
X-MS-Exchange-CrossTenant-fromentityheader: Hosted
X-MS-Exchange-CrossTenant-id: 84df9e7f-e9f6-40af-b435-aaaaaaaaaaaa
X-MS-Exchange-Transport-CrossTenantHeadersStamped: DB9P193MB1291
X-OVH-Remote: 40.92.75.96 (mail-vi1eur04olkn2096.outbound.protection.outlook.com)
X-Ovh-Tracer-Id: 12529014163568437483
X-VR-SPAMSTATE: OK
X-VR-SPAMSCORE: 50
X-VR-SPAMCAUSE: gggruggvucftvghtrhhoucdtuddrgedvledrieeggdelvdcutefuodetggdotefrodftvfcurfhrohhfihhlvgemucfqggfjpdevjffgvefmvefgnecuuegrihhlohhuthemucehtddtnecugfhmphhthicusghougihucdlhedtmdenucfjughrpefhvffuthffkfgtgfggsehtqhdttddttddvnecuhfhrohhmpefrhhhilhhiphhpihhnvgcurghnugcuffgruhhghhhtvghrshcuoehphhhilhhiphhpihhnvgdrfihirghrthesohhuthhlohhokhdrtghomheqnecuggftrfgrthhtvghrnhepheevgfehleefgfekgfeiveevfefhvddvvdevleejgfefvdehjeeifefhgfffhfetnecukfhppeegtddrledvrdejhedrleeipddviedtfeemuddtrgeimedutddvmegrtgemmedvfeenucevlhhushhtvghrufhiiigvpedtnecurfgrrhgrmhepihhnvghtpeegtddrledvrdejhedrleeipdhhvghlohepvghurhdtgedqvhhiuddqohgsvgdrohhuthgsohhunhgurdhprhhothgvtghtihhonhdrohhuthhlohhokhdrtghomhdpmhgrihhlfhhrohhmpehphhhilhhiphhpihhnvgdrfihirghrthesohhuthhlohhokhdrtghomhdpnhgspghrtghpthhtohepuddprhgtphhtthhopegtohhnthgrtghtsehphhhilhhiphhpihhnvgifihgrrhhtrdhfrhdpoffvtefjohhsthepvhhrfeehpdgukhhimhepphgrshhspdhsphhfpehprghsshdprhgvvhfkrfepmhgrihhlqdhvihduvghurhdtgeholhhknhdvtdeliedrohhuth
gsohhunhgurdhprhhothgvtghtihhonhdrohhuthhlohhokhdrtghomhdpghgvohfkrfeptefv
X-Ovh-Spam-Status: OK
X-Ovh-Spam-Reason: vr: OK; dkim: disabled; spf: disabled
X-Ovh-Message-Type: OK
(Ajoutez des screenshots si cela peut faciliter la compréhension de votre situation)
