put a laravel 9 project online on OVH using filezilla
Hello everyone,
I made a Laravel 9 project with a mysql database and I try to put it online with the OVH as host.
I used FileZilla to:
1. I checked the version of php in "composer.json" and updated on OVH to be the same.
2. I copied my project in the "www" directory (no failed tranfert)
3. I moved the contain of the public directory to be in the same place than the project file.
4. I updated my index.php by delete everything and adding the following code:
define('LARAVEL_START', microtime(true));
require__DIR__.'/ADA2023/vendor/autoload.php';
$app = require_once__DIR__.'/ADA2023/bootstrap/app.php';
"ADA2023" is the name of the project
And after that I saved but when I tried to access my project online with the name of my domain "https://adatfejogendarme2022.be/" I have the HTTP ERROR 500
