I've received 2 emails from OVH telling me that the anti-DDoS protection was enabled on the IP where I've my VPS. And twice, this protection was disabled, everything returned to normal.
I have several domains (sites) on my VPS, I would like to know on which domain the attack took place?
(Yes, I've tried looking at the logs, but it's not obvious.)
Or is it possible that the attack concerned a different domain than any of mine, but that is on the same IP?
If it's one of my sites that was attacked, I'll check whether there's a vulnerability I could fix...
Pas possible, le système anti-ddos protège une IP et non un nom de domaine.
That's what I was afraid of, and it's a shame. The information would have been useful.
Thanks anyway.
sauf que techniquement le système n'a pas l'information vu qu'il travail au couche 3/4.
Seule un anti-ddos travaillant sur les couches 3/4/7 pourrait avoir la statistique si elle est présente
