Technical questions before signing up
(I put a random tag, I don’t know what it means...)
Well, I intended to subscribe to a landline to complement the internet offer from a local associative ISP (I have very little mobile coverage at home, no smartphone). But given the hassle of getting information and my lack of technical skills for any installation, I’m afraid this project will fall through… I’ll still post my questions here, in case there are motivated people (volunteers I imagine, thanks to you!)
1/ Is the discovery offer at €1.19 compatible with a wired Gigaset DA120 phone currently connected to a box via an RJ11 jack?
2/ I get the impression an ATA adapter is needed for it to work. Do you provide it? If not, which models are compatible? Do they require configuration? (and if configuration is needed, do you provide support for that???)
3/ Is it possible to change the handset and/or adapter later on?
4/ Is there a maximum call duration on landlines in France with the €1.19 discovery offer? If so, what’s the pricing afterwards? (or is it possible to hang up and call the same number again without charge?)
5/ How are mobile calls in France billed?
6/ Are emergency numbers reachable (I don’t always have mobile coverage at home...)
7/ Is there any reachable support (I don’t have a smartphone, so without internet I can only call with my mobile)???
Thanks for any answers!
I will not answer on the pricing aspect so as not to say anything incorrect.
For your use case, I would suggest taking only the Discovery subscription, without acquiring equipment from OVH. That way you won’t be dependent on the Internet service provider and you can use the SIP account (you will have access to the password) on any device:
  • a SIP phone (which may have additional interfaces; see, for example, the recent discussion about the C530IP and the DX800A: Téléphone hybride SIP et analogique? - #10 par Jean_arthurS)
  • an adapter/converter (ATA) that provides a Z interface on which you can plug an analog phone
  • a smartphone, a Windows or Linux PC, a Mac with software such as Zoiper (there are others)
In all cases, you need an existing Internet connection, regardless of the medium (ADSL, fiber, cable, satellite, 3/4/5G mobile network...). The latter case allows a Wi‑Fi connection, the first two require a connection via an Ethernet port (exceptions may exist).
You will have a phone number, and additionally you can forward an existing (landline) number.
Subsidiary answers:
  • 6: in principle yes (I’ve never tried), if you correctly enter your home address (obviously, if you later use the account from another location, the call will be routed to the wrong place) and as long as you have electricity
  • 7: phone support yes, provided you are patient, but for a SIP account you’ll get answers right here (and if you have phone problems because you don’t have Internet, well, that’s where you’ll have to start)…
