Hi,
I'm discovering ovh public cloud these days and try to figure out how I can design the network.
As a basic test, I created 1 private subnet and try basic communication between an instance launched in the default public subnet and another launched in the private subnet.
When I tried to create a router that would be attached to both subnets, I get a :
$ openstack router create myrouter
ConflictException: 409: Client Error for url: https://network.compute.gra5.cloud.ovh.net/v2.0/routers, Quota exceeded for resources: ['router'].
I don't know where I can increase the quota…
Also, the horizon UI is supposed to have a "router" button but it seems not to be displayed.
Best,
Matthieu
PS : of course everything works if I add a second interface to the public instance and attach it to the private subnet.
Wow, I just saw this thread : https://community.ovhcloud.com/t/21700
Routers are an "alpha" feature and I've to create them by hand ? Is it true ?
Hello,
Yes, routers are only in alpha stage for now and are enabled on GRA9 region.
