Serveur planté après MAJ vers Ubuntu 22.04
Je suis sur un Kimsufi : Kimsufi mKS 2G
Hier j'ai tenté de passer de la version 20.04 LTS à la 22.04 LTS d'Ubuntu.
Au moment de redémarrer le serveur ne s'est jamais relancé.
J'ai tenté une réparation du grub sans succès.
Les derniers logs système n'ont à priori rien de concluants, en tout cas je ne vois rien qui expliquerait le problème :
Aug 26 20:37:03 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:03 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:09 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:09 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:14 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:14 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:19 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:19 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:25 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:25 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:29 ks3262589 systemd[1]: Starting Snap Daemon…
Aug 26 20:37:29 ks3262589 snapd[67723]: overlord.go:271: Acquiring state lock file
Aug 26 20:37:29 ks3262589 snapd[67723]: overlord.go:276: Acquired state lock file
Aug 26 20:37:30 ks3262589 snapd[67723]: daemon.go:247: started snapd/2.63+22.04ubuntu0.1 (series 16; classic; devmode) ubuntu/22.04 (amd64) linux/3.8.13-xxxx-grs-ipv6-64.
Aug 26 20:37:30 ks3262589 snapd[67723]: main.go:125: system does not fully support snapd: cannot mount squashfs image using "squashfs": mount: /tmp/syscheck-mountpoint-792928355: type de système de fichiers « squashfs » inconnu.
Aug 26 20:37:30 ks3262589 snapd[67723]: daemon.go:340: adjusting startup timeout by 30s (pessimistic estimate of 30s plus 5s per snap)
Aug 26 20:37:30 ks3262589 snapd[67723]: backends.go:58: AppArmor status: apparmor not enabled
Aug 26 20:37:30 ks3262589 systemd[1]: Started Snap Daemon.
Aug 26 20:37:30 ks3262589 dbus-daemon[3736]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.70' (uid=0 pid=67723 comm="")
Aug 26 20:37:30 ks3262589 systemd[1]: /usr/lib/systemd/system/systemd-timedated.service:26: Unknown key name 'ProtectProc' in section 'Service', ignoring.
Aug 26 20:37:30 ks3262589 systemd[1]: Starting Time & Date Service…
Aug 26 20:37:30 ks3262589 dbus-daemon[3736]: [system] Successfully activated service 'org.freedesktop.timedate1'
Aug 26 20:37:30 ks3262589 systemd[1]: Started Time & Date Service.
Aug 26 20:37:31 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:31 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:35 ks3262589 snapd[67723]: daemon.go:519: gracefully waiting for running hooks
Aug 26 20:37:35 ks3262589 snapd[67723]: daemon.go:521: done waiting for running hooks
Aug 26 20:37:36 ks3262589 transmission-daemon[55976]: [2024-08-26 20:37:36.792] Unable to create session lock file (22): Invalid argument (session-id.c:96)
Aug 26 20:37:37 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:37 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:38 ks3262589 snapd[67723]: overlord.go:515: Released state lock file
Aug 26 20:37:38 ks3262589 snapd[67723]: daemon stop requested to wait for socket activation
Aug 26 20:37:38 ks3262589 systemd[1]: snapd.service: Succeeded.
Aug 26 20:37:42 ks3262589 portsentry[4115]: attackalert: Connect from host: 167.94.138.135/167.94.138.135 to UDP port: 161
Aug 26 20:37:42 ks3262589 portsentry[4115]: attackalert: Ignoring UDP response per configuration file setting.
Aug 26 20:37:43 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:43 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:48 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:48 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:37:54 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:37:54 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:38:00 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:38:00 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:38:00 ks3262589 systemd[1]: systemd-timedated.service: Succeeded.
Aug 26 20:38:05 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:38:05 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:38:10 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:38:10 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:38:15 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:38:15 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:38:22 ks3262589 portsentry[4100]: attackalert: Connect from host: 47.197.163.127/47.197.163.127 to TCP port: 1080
Aug 26 20:38:22 ks3262589 portsentry[4100]: attackalert: Host: 47.197.163.127 is already blocked. Ignoring
Aug 26 20:38:26 ks3262589 systemd[1]: Stopping Session c1 of user root.
Aug 26 20:38:26 ks3262589 systemd[1]: Removed slice system-modprobe.slice.
Aug 26 20:38:26 ks3262589 systemd[1]: Removed slice system-postfix.slice.
Aug 26 20:38:26 ks3262589 systemd[1]: ureadahead-stop.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Stop ureadahead data collection 45s after completed startup.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped target Graphical Interface.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped target Multi-User System.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped target Login Prompts.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped target Host and Network Name Lookups.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped target System Time Set.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped target Timer Units.
Aug 26 20:38:26 ks3262589 systemd[1]: apt-daily-upgrade.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Daily apt upgrade and clean activities.
Aug 26 20:38:26 ks3262589 systemd[1]: apt-daily.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Daily apt download activities.
Aug 26 20:38:26 ks3262589 systemd[1]: certbot.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Run certbot twice daily.
Aug 26 20:38:26 ks3262589 systemd[1]: dpkg-db-backup.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Daily dpkg database backup timer.
Aug 26 20:38:26 ks3262589 systemd[1]: e2scrub_all.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Periodic ext4 Online Metadata Check for All Filesystems.
Aug 26 20:38:26 ks3262589 systemd[1]: fstrim.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Discard unused blocks once a week.
Aug 26 20:38:26 ks3262589 systemd[1]: logrotate.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Daily rotation of log files.
Aug 26 20:38:26 ks3262589 systemd[1]: man-db.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Daily man-db regeneration.
Aug 26 20:38:26 ks3262589 systemd[1]: mdcheck_continue.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped MD array scrubbing - continuation.
Aug 26 20:38:26 ks3262589 systemd[1]: mdcheck_start.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped MD array scrubbing.
Aug 26 20:38:26 ks3262589 systemd[1]: mdmonitor-oneshot.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Reminder for degraded MD arrays.
Aug 26 20:38:26 ks3262589 systemd[1]: motd-news.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Message of the Day.
Aug 26 20:38:26 ks3262589 systemd[1]: phpsessionclean.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Clean PHP session files every 30 mins.
Aug 26 20:38:26 ks3262589 systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Aug 26 20:38:26 ks3262589 systemd[1]: update-notifier-download.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Download data for packages that failed at package install time.
Aug 26 20:38:26 ks3262589 systemd[1]: update-notifier-motd.timer: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopped Check to see whether there is a new version of Ubuntu available.
Aug 26 20:38:26 ks3262589 systemd[1]: lvm2-lvmpolld.socket: Succeeded.
Aug 26 20:38:26 ks3262589 systemd[1]: Closed LVM2 poll daemon socket.
Aug 26 20:38:26 ks3262589 systemd[1]: Stopping Accounts Service…
Aug 26 20:38:26 ks3262589 systemd[1]: Stopping Interface between MTA and virus scanner/content filters…
Aug 26 20:38:26 ks3262589 systemd[1]: Stopping Disk Cache Cleaning Daemon for Apache HTTP Server…
Aug 26 20:38:27 ks3262589 authdaemond: stopping authdaemond children
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping LSB: automatic crash report generation…
Aug 26 20:38:27 ks3262589 ntpd[52928]: ntpd exiting on signal 15 (Terminated)
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Deferred execution scheduler…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 82.67.71.253 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping LSB: Bastille Firewall…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 176.137.36.37 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: WARNING: reverting to default settings (dropping firewall)
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: disabling IP forwarding… done.
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Availability of block devices…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 51.195.104.188 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: unloading masquerading modules…
Aug 26 20:38:27 ks3262589 bastille-firewall[67814]: libkmod: ERROR ../libkmod/libkmod-module.c:1668 kmod_module_new_from_loaded: could not open /proc/modules: No such file or directory
Aug 26 20:38:27 ks3262589 bastille-firewall[67814]: Error: could not get list of modules: No such file or directory
Aug 26 20:38:27 ks3262589 blkdeactivate[67785]: Deactivating block devices:
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Courier Authentification Daemon…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 51.68.44.27 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: done.
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Regular background program processing daemon…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 185.125.190.57 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: resetting default input rules to accept…
Aug 26 20:38:27 ks3262589 bastille-firewall[67817]: /sbin/bastille-ipchains: line 621: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Create final runtime dir for shutdown pivot root…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 82.67.62.62 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Getty on tty1…
Aug 26 20:38:27 ks3262589 ntpd[52928]: 185.125.190.56 local addr 5.39.77.120 ->
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: resetting default output rule to accept…
Aug 26 20:38:27 ks3262589 bastille-firewall[67818]: /sbin/bastille-ipchains: line 624: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping LSB: disk temperature monitoring daemon…
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping irqbalance daemon…
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: resetting default forward rule to accept…
Aug 26 20:38:27 ks3262589 bastille-firewall[67819]: /sbin/bastille-ipchains: line 629: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping MySQL Community Server…
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Dispatcher daemon for systemd-networkd…
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: flushing input rules…
Aug 26 20:38:27 ks3262589 bastille-firewall[67820]: /sbin/bastille-ipchains: line 633: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Network Time Service…
Aug 26 20:38:27 ks3262589 blkdeactivate[67785]: [MD]: deactivating md device md0…
Aug 26 20:38:27 ks3262589 blkdeactivate[67843]: cat: /sys/block/md0/md/sync_action: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: openvpn.service: Succeeded.
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: flushing output rules…
Aug 26 20:38:27 ks3262589 bastille-firewall[67821]: /sbin/bastille-ipchains: line 633: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopped OpenVPN service.
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping PackageKit Daemon…
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: flushing forward rules…
Aug 26 20:38:27 ks3262589 bastille-firewall[67822]: /sbin/bastille-ipchains: line 633: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping Authorization Manager…
Aug 26 20:38:27 ks3262589 bastille-firewall[67795]: removing user-defined chains…
Aug 26 20:38:27 ks3262589 bastille-firewall[67823]: /sbin/bastille-ipchains: line 639: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 bastille-firewall[67824]: /sbin/bastille-ipchains: line 640: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 bastille-firewall[67825]: /sbin/bastille-ipchains: line 639: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopping LSB: # start and stop portsentry…
Aug 26 20:38:27 ks3262589 bastille-firewall[67826]: /sbin/bastille-ipchains: line 640: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: postfix.service: Succeeded.
Aug 26 20:38:27 ks3262589 bastille-firewall[67827]: /sbin/bastille-ipchains: line 639: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 bastille-firewall[67828]: /sbin/bastille-ipchains: line 640: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 bastille-firewall[67829]: /sbin/bastille-ipchains: line 639: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 bastille-firewall[67830]: /sbin/bastille-ipchains: line 640: /sbin/ipchains: No such file or directory
Aug 26 20:38:27 ks3262589 systemd[1]: Stopped Postfix Mail Transport Agent.
Aug 26 20:38:27 ks3262589 systemd[1]: postgresql.service: Succeeded.
Aug 26 20:38:27 ks3262589 blkdeactivate[67785]: action in progress… done
Aug 26 20:38:27 ks3262589 kernel: md: md0 stopped.
Aug 26 20:38:27 ks3262589 systemd[1]: Stopped PostgreSQL RDBMS.
Voici mon boot info :
Boot Info Script 0.78 [09 October 2019]
============================= Boot Info Summary: ===============================
=> Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of
the same hard drive for core.img. core.img is at this location and looks
for (,msdos1)/boot/grub. It also embeds following components:
modules
fshelp ext2 part_msdos biosdisk
sda1: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System: Ubuntu 22.04.4 LTS
Boot files: /boot/grub/grub.cfg /etc/fstab
/boot/grub/i386-pc/core.img
sda2: __________________________________________________________________________
File system: ext4
Boot sector type: -
Boot sector info:
Operating System:
Boot files:
sda3: __________________________________________________________________________
File system: swap
Boot sector type: -
Boot sector info:
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 465.8 GiB, 500107862016 bytes, 976773168 sectors
Disk model: ST500DM002-1BD14
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Partition Boot Start Sector End Sector # of Sectors Id System
/dev/sda1 * 4,096 40,962,047 40,957,952 83 Linux
/dev/sda2 40,962,048 975,718,399 934,756,352 83 Linux
/dev/sda3 975,718,400 976,764,927 1,046,528 82 Linux swap / Solaris
"blkid" output: ________________________________________________________________
Device UUID TYPE LABEL
/dev/sda1 3988e982-cb15-4e6e-87d8-0f4482e37791 ext4
/dev/sda2 29455ecb-7616-429a-bc2e-1211c7b3f0d7 ext4
/dev/sda3 4bfd8eea-469d-40ee-899c-f7a1d8dcbaeb swap
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root 9 Aug 27 10:52 ata-ST500DM002-1BD142_Z3T3SHXM -> ../../sda
lrwxrwxrwx 1 root root 10 Aug 27 10:52 ata-ST500DM002-1BD142_Z3T3SHXM-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Aug 27 10:52 ata-ST500DM002-1BD142_Z3T3SHXM-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Aug 27 10:52 ata-ST500DM002-1BD142_Z3T3SHXM-part3 -> ../../sda3
lrwxrwxrwx 1 root root 9 Aug 27 10:52 wwn-0x5000c5004e2d07b6 -> ../../sda
lrwxrwxrwx 1 root root 10 Aug 27 10:52 wwn-0x5000c5004e2d07b6-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Aug 27 10:52 wwn-0x5000c5004e2d07b6-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Aug 27 10:52 wwn-0x5000c5004e2d07b6-part3 -> ../../sda3
================================ Mount points: =================================
Device Mount_Point Type Options
/dev/sda1 /mnt ext4 (rw,relatime)
=========================== sda1/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
set have_grubenv=true
load_env
fi
if [ "${initrdfail}" = 2 ]; then
set initrdfail=
elif [ "${initrdfail}" = 1 ]; then
set next_entry="${prev_entry}"
set prev_entry=
save_env prev_entry
if [ "${next_entry}" ]; then
set initrdfail=2
fi
fi
if [ "${next_entry}" ] ; then
set default="${next_entry}"
set next_entry=
save_env next_entry
set boot_once=true
else
set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
menuentry_id_option="–id"
else
menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
set saved_entry="${prev_saved_entry}"
save_env saved_entry
set prev_saved_entry=
save_env prev_saved_entry
set boot_once=true
fi
function savedefault {
if [ -z "${boot_once}" ]; then
saved_entry="${chosen}"
fi
function initrdfail {
if [ -n "${have_grubenv}" ]; then if [ -n "${partuuid}" ]; then
if [ -z "${initrdfail}" ]; then
set initrdfail=1
if [ -n "${boot_once}" ]; then
set prev_entry="${default}"
save_env prev_entry
fi
fi
save_env initrdfail
fi; fi
function recordfail {
set recordfail=1
if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
if [ x$feature_all_video_module = xy ]; then
insmod all_video
else
insmod efi_gop
insmod efi_uga
insmod ieee1275_fb
insmod vbe
insmod vga
insmod video_bochs
insmod video_cirrus
fi
if [ x$feature_default_font_path = xy ] ; then
font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1 3988e982-cb15-4e6e-87d8-0f4482e37791
else
search --no-floppy --fs-uuid --set=root 3988e982-cb15-4e6e-87d8-0f4482e37791
fi
font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
set gfxmode=auto
load_video
insmod gfxterm
set locale_dir=$prefix/locale
set lang=en_US
insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
set timeout=30
else
if [ x$feature_timeout_style = xy ] ; then
set timeout_style=hidden
set timeout=2
# Fallback hidden-timeout code in case the timeout_style feature is
# unavailable.
elif sleep --interruptible 2 ; then
set timeout=0
fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/06_OVHkernel ###
menuentry "Ubuntu 12.04, OVH kernel 3.8.13-xxxx-grs-ipv6-64" {
insmod part_msdos
insmod ext2
else
fi
linux /boot/bzImage-3.8.13-xxxx-grs-ipv6-64 root=/dev/sda1 ro
### END /etc/grub.d/06_OVHkernel ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
set gfxpayload="${1}"
if [ "${1}" = "keep" ]; then
set vt_handoff=vt.handoff=7
else
set vt_handoff=
fi
if [ "${recordfail}" != 1 ]; then
if [ -e ${prefix}/gfxblacklist.txt ]; then
if [ ${grub_platform} != pc ]; then
set linux_gfx_mode=keep
elif hwmatch ${prefix}/gfxblacklist.txt 3; then
if [ ${match} = 0 ]; then
else
set linux_gfx_mode=text
fi
else
fi
else
fi
else
fi
export linux_gfx_mode
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/10_linux_zfs ###
### END /etc/grub.d/10_linux_zfs ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f ${config_directory}/custom.cfg ]; then
source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
source $prefix/custom.cfg
fi
### END /etc/grub.d/41_custom ###
=============================== sda1/etc/fstab: ================================
/dev/sda1 / ext4 errors=remount-ro,relatime 0 1
/dev/sda2 /home ext4 defaults,relatime 1 2
/dev/sda3 swap swap defaults 0 0
proc /proc proc defaults 0 0
sysfs /sys sysfs defaults 0 0
devtmpfs /dev devtmpfs rw 0 0--------------------------------------------------------------------------------
=================== sda1: Location of files loaded by Grub: ====================
GiB - GB File Fragment(s)
14.877090454 = 15.974154240 boot/grub/grub.cfg 1
11.625022888 = 12.482273280 boot/grub/i386-pc/core.img 1
=============================== StdErr Messages: ===============================
mdadm: No arrays found in config file or automatically
Je vous remercie d'avance pour votre aide car j'avoue je sèche :confused:
Bonne journée !
Je vais jeter un œil aux informations données. Pouvez-vous SVP utiliser des blocs pour rendre plus lisible la sortie des commandes ?
```text
ligne 1
ligne 2
etc.
Pouvez-vous donner la sortie de ces commandes ?
```text
lsblk
lsblk -f
J'ai l'impression que votre installation avait été faite avec un très ancien kernel OVH. Je vous conseille de le désinstaller et d'installer `linux-image-amd64` à la place.
Bonjour @le_sbraz,
merci pour votre intérêt.
Je viens de modifier mon premier post.
Je pensais justement avoir formaté mon texte.
Je repasse en mode rescue et je poste le résultat.
Mais effectivement je pense être encore sur un ancien kernel.
C'est loin tout ça donc je vais vérifier comment changer de kernel de mon côté.
Voici donc le retour des 2 commandes :
root@rescue-customer-eu:/# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 19.5G 0 part /
├─sda2 8:2 0 445.7G 0 part
└─sda3 8:3 0 511M 0 part
nbd0 43:0 0 0B 0 disk
nbd1 43:32 0 0B 0 disk
nbd2 43:64 0 0B 0 disk
nbd3 43:96 0 0B 0 disk
nbd4 43:128 0 0B 0 disk
nbd5 43:160 0 0B 0 disk
nbd6 43:192 0 0B 0 disk
nbd7 43:224 0 0B 0 disk
nbd8 43:256 0 0B 0 disk
nbd9 43:288 0 0B 0 disk
nbd10 43:320 0 0B 0 disk
nbd11 43:352 0 0B 0 disk
nbd12 43:384 0 0B 0 disk
nbd13 43:416 0 0B 0 disk
nbd14 43:448 0 0B 0 disk
nbd15 43:480 0 0B 0 disk
root@rescue-customer-eu:/# lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
sda
├─sda1 6.5G 61% /
├─sda2
└─sda3
nbd0
nbd1
nbd2
nbd3
nbd4
nbd5
nbd6
nbd7
nbd8
nbd9
nbd10
nbd11
nbd12
nbd13
nbd14
nbd15
Ah en effet vous n'avez qu'un seul disque, le partitionnement est très simple. Dites-moi ce que ça donne après avoir installé le kernel Ubuntu de base.
Re,
donc j'ai eu le temps en début de soirée d'installer un nouveau Kernel.
J'ai regardé ceux qu'on me proposait pour la distribution.
Je suis parti sur le 6.8.0-40-generic
Et ça a l'air d'être reparti. :slight_smile:
Merci beaucoup pour m'avoir aidé et mis sur la piste du kernel @le_sbraz
Et bonne soirée !
Avec plaisir :slight_smile: Pour que le kernel reste bien mis à jour, je vous conseille d'utiliser le metapaquet associé (linux-generic-hwe-22.04) qui tirera automatiquement le kernel à jour lors des updates.
Merci du conseil :slight_smile:
Je l'installe de ce pas.
