[Solved] Redirection IP not updated
Hello,
I moved to a new VPS and I'm trying to reconfigure my redirections but with no success
My old redirections still point to the old VPS even after 24 hours of the modification
When I create a new redirection, it's immediately available with the new IP but the old ones won't update
I have a domain + VPS on OVH so I'm using the OVH manager to update the IPs
Do you have any ideas how to solve this?
Edit:
I had to delete and add the redirections again to solve this
Thank you for your help
glad to hear you are sorted . if you face similar issues revert back.
Thanks.
Thank you for your reply,
I will mark it as solved, I didn't encounter more issues on this matter
Kind regards
