URGENT – FastCGI errors AH10143 / AH10149 / AH10157 on OVH shared hosting – Elementor blocked (HTTP 500)
Hello everyone,
I’m reaching out for help because I’ve been completely stuck with my site for over a month and cannot solve the issue despite many tests.
I opened a ticket with OVH on September 22, but haven’t received a response yet.
Hosting concerned: christineguichard.fr
Issue encountered
I can no longer open the Elementor editor for my WordPress site (the /modify‑with‑elementor page). The page stays blank and eventually returns an HTTP 500 error after several minutes of waiting.
The public site, however, displays normally.
Errors reported in the OVH logs
  • AH10143 : FastCGI communication aborted: read failed
  • AH10149 : FastCGI incomplete headers (0 bytes)
  • AH10157 : An error happened during FastCGI processing, fallback to CGI
  • End of script output before headers: index.php
Similar errors also appear when executing wp-admin/admin-ajax.php.
Tests already performed
  • The problem is reproducible, even on an empty test page.
  • It persists in Elementor safe mode.
  • It persists with all additional plugins disabled.
  • Several PHP versions have been tested: 8.1, 8.2 and 8.3.
  • PHP memory is set to 512 MB.
  • The maximum execution time has been raised to 300 seconds.
  • The Elementor cache has been cleared.
  • The WordPress and site URLs are identical.
  • No corresponding fatal error appears in the WordPress debug.log.
My request
I would like to know whether these FastCGI errors could be related to a PHP process interruption, a hosting resource limit, or a server‑side execution problem.
My OVH ticket specifically mentions the errors observed on 22/09/2026 at 15:27 and 15:28, on cluster030.
If anyone has encountered this type of issue or knows how to get a more detailed technical analysis from OVH, I would be very grateful for guidance.
This blockage has prevented me from working on my site for over a month.
Thank you very much for your help and advice.
Christine
Hi @ChristineG15
Thank you for the detailed information.
I think the problem is excessive resource consumption. The PHP process is trying to use more memory or CPU time than the plan provides.
The hosting plan has a limited number of “workers” (PHP‑FPM processes) to handle requests. If they’re all busy with slow tasks, such as some from Elementor, new requests remain unserved or are rejected, causing this type of errors and failures in admin-ajax.php.
Even if your "Pro" plan has 512M, the problem may be the limit on simultaneous processes or CPU time, which cannot be adjusted on a shared plan :smirking_face:
To get out of the deadlock, the most reliable solution is to upgrade to a higher‑tier plan such as a VPS.
Kind regards,
Sergio Turpín
Hello @sturpin,
Thanks for your response. Your hypothesis of a resource saturation is plausible.
Since this is still a hypothesis and you probably don’t have access to the internal metrics of my hosting, could you tell me what specific information I should request from OVH support to confirm or rule out this hypothesis before migrating to a VPS?
I would especially like to know whether OVH support can check, at the times of the AH10143 / AH10149 / AH10157 errors, if my hosting has reached a limit for:
  • workers/PHP‑FPM processes;
  • CPU;
  • memory;
  • execution time;
  • or any other resource limit of the Pro plan.
If no saturation is observed, I would also like to know if OVH can verify a possible PHP‑FPM/FastCGI issue on the affected cluster.
My goal is simply to confirm the cause before migrating to a VPS, so as not to undertake a migration and extra cost without certainty that it will solve the problem.
Thank you very much for your help.
Christine
Hi @ChristineG15
Yes, we will first do an analysis of what we already have. Have you checked the logs?
https://docs.ovhcloud.com/es/guides/web-cloud/web-hosting/logs-and-statistics
Also review the technical specifications of your hosting:
https://docs.ovhcloud.com/en/guides/web-cloud/web-hosting/hosting-technical-specificities
Regarding Support you can phrase it as follows:
I have FastCGI errors (AH10143, AH10149, AH10157) on my hosting [christineguichard.fr, cluster030] that appear when using Elementor. I have reviewed the infrastructure statistics and see that CPU usage spikes at those moments. I need to know:
  1. At the exact moments of the errors (provide date/time), did the hosting reach the limit of PHP-FPM processes allocated to my plan?
  2. Was there a memory exhaustion or CPU time limit reached at the server level?
  3. Was the PHP-FPM pool of cluster030 saturated at that time, affecting other customers?
I need this information to determine whether a higher plan would solve the problem or if the cause is something else.
Keep me informed, best regards.
Sergio Turpín
¿Cómo puedo crear un ticket de soporte?
Haz clic en este enlace para crear una solicitud de soporte desde el Centro de ayuda de OVHcloud. A continuación, inicia sesión con tus credenciales de OVHcloud.
Una vez que hayas iniciado sesión, haz clic ✉ Tickets en el Ticket creation botón. Selecciona el motivo de tu solicitud y, a continuación, el producto y el servicio en cuestión. Luego, especifica tu solicitud para acceder a sugerencias personalizadas de ayuda y asesoramiento. Si esto no satisface tus necesidades, haz clic Nextpara completar tu solicitud y crear un ticket de soporte. Asegúrate de proporcionar toda la información posible para que nuestros equipos puedan ayudarte mejor.
Hello @sturpin, thank you very much for your reply. This lead concerning PHP‑FPM process saturation is interesting and could indeed explain the FastCGI errors I’m observing.
Since you are a forum participant rather than OVH support, I understand you don’t have access to my hosting metrics.
In your opinion, are the AH10143 / AH10149 / AH10157 errors I have in the logs characteristic enough of a PHP‑FPM worker saturation to justify migrating to a VPS?
Or do you think it would be better for me to press OVH support to first check the PHP resources/processes of my Pro plan before migrating?
I mainly want to avoid moving to a VPS without being sure the problem truly stems from a limit of my hosting.
Thanks again for your help, as I’ve been stuck for more than a month and I’m really trying to identify the cause before changing my plan.
Thanks @sturpin for the suggestion! I’ve already checked that in the meantime:
  • PHP memory and execution time: already very generous without any changes (512 M / 165 s via ini_get()), so this is not the limiting factor.
  • wp_postmeta table: 26.2 MiB, which is normal for my site (shop + portfolio), no sign of an overloaded database.
  • Cleaning with WP‑Sweep: already done (revisions, transients, etc. cleaned) — no effect on the issue.
  • Full reinstallation of Elementor and all its addons: also done, the problem persists unchanged.
The real symptom confirmed in the Apache logs: the REST requests wp-json/elementor/v1/global-classes and kit-elements-defaults take between 17 seconds and several minutes before failing with a 500 error, accompanied by FastCGI: comm with server aborted: read failed. This looks like an abnormally slow server‑side calculation (or a blocking external call), not a full database.
Have you ever seen this specific case (specifically related to the new global-classes/containers endpoints of Elementor)? Have a good evening, Christine
