Urgent--web hosting problem
first my site is : https://recipes-of-annie.com/
the problem is when i change my theme or update any thing in my site , in mobile nothing change no theme change or post ( the new and the old post) it only show the last theme here exemple
this is in desktop : !Capture|690x312
this is on mobile : !Screenshot_20201223-095543|236x500
the old theme only and when i move to the next page on mobile other old theme appear
i tried to delete all in my host ( theme and plugins and data base) but still the some problem
any one can help me plz
I understand Your Problem. You firstly see your Plugins which are installed on your site. Because in such cases irrelevant plugins show errors. I also face such problems when I update any article or post on my tesco bill website.
Try to switch browser maybe it will help
[url=https://cebuinsights.com/]Cebu Travel Guide[/url]
I also face such problems like you when I set my https://hirelaptops.com.au/ laptop rental website. Hosting is really important for website. You must choose the right platform for web hosting.
Web host help desks are staffed with non-technical employees who fail to understand the urgency of the reported issue. I also face issue of web hosting. But I rapidly remove this problem, https://toolsofchef.com/best-japanese-knife-brands/ click for more info
Hi,
Firstly you should disable your website cache plugin because most of the time this type of issue occurs due to the cache plugin. Secondly, you can clear all the cache files of your website this will also help you. If these two methods not working properly so you can check the . This website will definitely help you regarding server & hosting issues.
