Hello all
The upgrade path to new ranges we are offering
!27|690x393
Meaning :
* You will keep your PCC (users, rights, IP, vRack, Datastores(if compatible with global)
* You will add a new vDC inside your current PCC, you will be able to add new hosts
* You will not lose your backup Veeam
* you will be able to use vMotion to move your VMs individually as VM can communicate on the same LAN VMware
* is feasible with no to minimal downtime
* hot vMotion is feasible from Intel to Intel
*cold vMotion is required from AMD to Intel
We created this post to list all technical question regarding the migration
We remain available
I've an educational website, main issue is that my backup for some newly uploaded pages not created, Idk why.
my webpages are https://ectipakistan.com/learn-english-with-ecti/ what is verb.
