vRack multi-region private network — no connectivity between DE1 and SBG5 instances
Service/Project: ProjectTest1 (3ecccdb3877d49a5b37c6cebe895306c)
vRack: pn-1330697 (confirmed active and attached to ProjectTest1)
Description:
I'm testing vRack connectivity between two Public Cloud instances in different regions, and private-network traffic is not passing between them at all.
Setup:
  • Private network: TestNET1, VLAN ID 10
  • Region 1: DE1 (Frankfurt) — CIDR 10.10.0.0/16, gateway 10.10.0.1
  • Region 2: SBG5 (Strasbourg) — CIDR 10.11.0.0/16, gateway 10.11.0.1
  • Both regions were added to the same TestNET1 network via the Public Cloud manager (Private Network → Regions (vRack) → Add Private Network), confirmed showing as one network with two regional rows.
  • vRack pn-1330697 is active and ProjectTest1 is listed as an attached service.
Instances:
  • Frankfurt VM: b3-16-2026_07_08-16-24, private IP 10.10.2.33
  • Strasbourg VM: b3-16-2026_07_10-11-56, private IP 10.11.1.66
Problem:
  • ping 10.11.1.66 from the Frankfurt VM → 100% packet loss
  • ping 10.10.2.33 from the Strasbourg VM → 100% packet loss
  • Pinging the local gateway itself from within each VM also times out (e.g., ping 10.10.0.1 from Frankfurt, ping 10.11.0.1 from Strasbourg) — both 100% loss
  • Windows Firewall inbound rule "File and Printer Sharing (Echo Request - ICMPv4-In)" is enabled on both VMs, so this isn't a host-level firewall issue
  • route print on the Strasbourg VM shows a correct default route via 10.11.0.1 (metric 16) — routing configuration on the VM side looks as expected; the issue appears to be upstream of the instance
Regards,
Manos
Hi,
https://network.status-ovhcloud.com/ maybe?
I don't think there is an ovh network problem. My virtual machines are in Strasbourg (SBG5) and Frankfurt (DE1). The "Current Events" are about problems in GRAvelines Area.
You should call support to get a ticket number (which you can put here), I think.
There are multiple people complaining about the RZO right now (but haven’t seen this specific peculiarity on UDP).
I can't create a ticket. The OVH support system is not working! :frowning:
by phone?
Luckily I was able to send a ticket.
Hello @cyberlogic
All you have left to do is call OVH support at +33 9 72 10 10 07.
Preferably between 8 a.m. and 9 a.m. in the morning, or around 3 p.m. when there’s less waiting.
Or on Twitter @ovh_support_fr or #OVHcloudsupport
