I'm trying to host my project to OVH server. I'm a beginner and I need to know the steps for deployment on ovh I use the angular front end and node js backend, and mon DB is MongoDB.
I think You should read guidelines and Support Visual, Surly That must be helped ful for you. https://www.olehanakorea.com/ Thanks.
