What products are available to use with Startup Program credits?
Introduction:
As part of OVHcloud's Startup Program, the credits provided help startups build, a flexible and scalable server infrastructure. However, not all solutions are eligible for use with Startup Program credits. This guide explains which solutions are eligible, how to consult the eligible solutions table, and important exceptions to be aware of.
Key Points:
  • Eligible solutions: Startup Program credits are primarily for server infrastructure solutions, such as Public Cloud and Private Cloud.
  • Non-Eligible solutions: Web and Telecom solutions, along with certain specific infrastructure solutions, are not covered by the credits.
  • Non-Eligible GPU solutions: Some Public Cloud instances and AI solutions using GPUs (A100, H100, L4, L40S) are not covered by the credits.
  • Order Error Handling: If non-eligible solutions are ordered by mistake, they must be stopped or transferred to another customer account not part of the Startup Program.
Steps to Follow:
1. Consult the Eligible Solutions Table
To find out which solution are eligible for your Startup Program credits, it is important to consult the eligible solutions table provided by OVHcloud. Credits are primarily intended for server infrastructure solutions such as:
  • Public Cloud: A cloud ecosystem of standard solutions to accelerate your business.
  • Private Cloud: Leverage VMware virtualization on dedicated, managed infrastructures to save time and gain agility with OVHcloud’s Managed VMware vSphere solutions.
Here is a summary of eligible solutions:
RangeSolutionsEligibility
Hosted Private Cloud
WMware (Managed vSphere, Hyperconverged Storage, Network Security Virtualization, Softaware-Defined Datacentre)
Compliance & Certifications: Healthcare, SecNumCloud, HIPAA & HITECH, PCI-DSS
Public cloud
Compute: Instances (excluding instances using GPUs A100, H100, L4, L40S), Baremetal Cloud
Storage & Backup: Block Storage, Object Storage, Cloud Archive, Cold Archive, Snapshot, Backup
Network: Load Balancer, vRack (Free), Bande passante, Floating IP, Gateway, Anti-DDoS
Containers & Orchestration: Managed K8s Service, Managed Rancher Service, Managed K8s Load Balancer, Managed Private Registry, Workflow Management, Image Catalog
Databases: MySQL, PostgreSQL, MongoDB, Kafka,Caching, OpenSearch, Kafka MirrorMaker, Kafka Connect, Grafana, Cassandra, M3DB, M3 Aggregator
Data Analytics: Data Processing (Excluding Logs Data Platform)
AI & Machine Learning (excluding AI solutions using GPUs A100, H100, L4, L40S): AI Notebooks, Quantum Notebooks, AI Training, AI deploy, NVIDIA NGC Platform
Quantum computing: Quantum Notebooks
Data Platform (Beta): Data Catalog, Data Processing Engine, Lakehouse Manager, Analytics Manager, Application Services, Data Platform capacity compute option
Soon
AI & Machine Learning (Alpha): AI Endpoint
Soon
Bare Metal & VPS
Managed Bare Metal ("Essentials" range powered by VMware)
Dedicated Servers
Storage: NAS-HA, Enterprise File Storage
VPS
Web Cloud
Domains, Web Hosting, Web PaaS, Emails, Collaborative Solutions
TelecomFiber, Broadband Access, Telephony, SMS, Fax, OverTheBox
Support
Business Support is free for Startup members at the "Scale" level
2. What to do if you order non-eligible solutions?
If non-eligible solutions are ordered by mistake, follow these steps:
  • Transfer the Instances: If you ordered non-eligible GPU instances, we will contact you to stop and recreate them on another client account not in the Startup Program.
    • Follow this Guide: Use our guide to transfer your instances to another client account.
  • If you don't want to stop the Instances: If you choose not to stop the non-eligible instances, OVHcloud may terminate your participation in the Startup Program.
Conclusion:
OVHcloud Startup Program credits are designed to support startups by providing them with server infrastructure solutions that meet high availability and scalability needs. It’s crucial to check the eligibility of the solutions you plan to use with your credits by consulting the eligible solutions table. If non-eligible solutions are ordered by mistake, follow the steps to correct the situation or transfer the instances to another account. Maximize your credits by focusing on flexible solutions that best suit your startup’s growth.
Hello @FabL ,
are there some green checkmarks and some other red crosses hidden behind the work "image" , as it happens frequently with the forum ?
I meant "word" and not "work" , but as usual the "Edit" function does nothing.
Hello @fritz2cat 🇧🇪 🇪🇺 ,
Est-ce que tu peux me dire sur quel os et quel navigateur tu constates ça s'il te plaît ?
Merci d'avance,
^FabL
C'est toujours le cas à l'instant, mais les borders ont disparu.
Windows 11 à jour, Firefox à jour.
À priori, ce serait côté OS. Nous ne pourrons pas intervenir.
Je vais chercher une alternative pour que ce soit visible.
Merci pour l'alerte.
^FabL
Quoi ? Vous ne supportez pas vos clients en W11 ?
Edge ce n'est pas beaucoup mieux que Firefox. Il y a les lignes mais pas les images non plus.
If someone tries to read those images, open the browser's developer tools, select inspector and hover over image. You will see two classes
- class="emoticon emoticon-cross community_image_fullscreen" which corresponds to https://confluence.ovhcloud.tools/s/-inpdeb/8804/xgjkrn/_/images/icons/emoticons/error.svg
- class="emoticon emoticon-tick community_image_fullscreen" which corresponds to: https://confluence.ovhcloud.tools/s/-inpdeb/8804/xgjkrn/_/images/icons/emoticons/check.svg
We can read from this that if it is tick, you have it, if it is cross you don't
With that in mind, Startup credits mostly cover Public Cloud, exception in Support and managed bare maetals (VMWare based)
Range Solutions Eligibility
Hosted Private Cloud WMware (Managed vSphere, Hyperconverged Storage, Network Security Virtualization, Software-Defined Datacentre) :white_check_mark:
Compliance & Certifications: Healthcare, SecNumCloud, HIPAA & HITECH, PCI-DSS :white_check_mark:
Public cloud Compute: Instances (excluding instances using GPUs A100, H100, L4, L40S), Baremetal Cloud :white_check_mark:
Storage & Backup: Block Storage, Object Storage, Cloud Archive, Cold Archive, Snapshot, Backup :white_check_mark:
Network: Load Balancer, vRack (Free), Bande passante, Floating IP, Gateway, Anti-DDoS :white_check_mark:
Containers & Orchestration: Managed K8s Service, Managed Rancher Service, Managed K8s Load Balancer, Managed Private Registry, Workflow Management, Image Catalog :white_check_mark:
Databases: MySQL, PostgreSQL, MongoDB, Kafka, Caching, OpenSearch, Kafka MirrorMaker, Kafka Connect, Grafana, Cassandra, M3DB, M3 Aggregator :white_check_mark:
Data Analytics: Data Processing (Excluding Logs Data Platform) :white_check_mark:
AI & Machine Learning (excluding AI solutions using GPUs A100, H100, L4, L40S): AI Notebooks, Quantum Notebooks, AI Training, AI deploy, NVIDIA NGC Platform :white_check_mark:
Quantum computing: Quantum Notebooks :white_check_mark:
Data Platform (Beta): Data Catalog, Data Processing Engine, Lakehouse Manager, Analytics Manager, Application Services, Data Platform capacity compute option Soon
AI & Machine Learning (Alpha): AI Endpoint Soon
Bare Metal & VPS Managed Bare Metal ("Essentials" range powered by VMware) :white_check_mark:
Dedicated Servers :cross_mark:
Storage: NAS-HA, Enterprise File Storage :cross_mark:
VPS :cross_mark:
Web Cloud Domains, Web Hosting, Web PaaS, Emails, Collaborative Solutions :cross_mark:
Telecom Fiber, Broadband Access, Telephony, SMS, Fax, OverTheBox :cross_mark:
Support Business Support is free for Startup members at the "Scale" level :white_check_mark:
