A few seconds after connecting to my VPN through CentOS 7 on my virtual machine, I lose connection with no errors in the log. This only appears to be happening with CentOS 7/8. OVH documentation (https://docs.ovh.com/gb/en/dedicated/network-bridging/) covers adding either
51.195.234.254 - 255.255.255.255 eth0
51.195.234.0 - 255.255.255.0 eth0
default 51.195.234.254
or
51.195.234.254 dev eth0
default via 51.195.234.254
to /etc/sysconfig/network-scripts/route-eth0 however this does not help.
Debian 10 (working):
ip a
1: lo: mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 02:00:00:ff:3b:ea brd ff:ff:ff:ff:ff:ff
inet 145.239.xxx.xxx/32 brd 145.239.xxx.xxx scope global eth0
inet6 fe80::ff:feff:3bea/64 scope link
ip r
default via 51.195.234.254 dev eth0
51.195.234.254 dev eth0 scope link
After connecting to VPN: ip r
0.0.0.0/1 via 10.8.0.9 dev tun0
10.8.0.0/24 via 10.8.0.9 dev tun0
10.8.0.9 dev tun0 proto kernel scope link src 10.8.0.10
VPNIP via 51.195.234.254 dev eth0
128.0.0.0/1 via 10.8.0.9 dev tun0
CentOS 7:
ip a
inet 145.239.xxx.xxx/32 brd 145.239.xxx.xxx scope global dynamic eth0
valid_lft 21599969sec preferred_lft 21599969sec
ip r
I have also tried adding the gateway of the VPN
ip route add 5.45.126.254 dev eth0
ip r
0.0.0.0/1 via 10.8.0.17 dev tun0
5.45.126.254 dev eth0 scope link
10.8.0.0/24 via 10.8.0.17 dev tun0
10.8.0.17 dev tun0 proto kernel scope link src 10.8.0.18
128.0.0.0/1 via 10.8.0.17 dev tun0
Could I have to maybe modify VPNIP via 51.195.234.254 dev eth0 so that it's routed through VPNIP via 5.45.126.254 dev eth0 ? if so how can I achieve that.
