Wordpress theme problem
Hello,
I have a problem when installing and viewing a theme on wordpress .
To be more precise: when I activate a theme it doesn’t appear as expected, the expected images do not load, so I only get a few minimal changes (without css and image) each time I change the theme.
I used the version provided by ovh then I manually installed version 5.6.2.
I have reinstalled wordpress and the data base several times and always had the same result.
Do you ave any idea what the problem is?
Thank you in advance.
I also have same issue at my website of pesco bill. Kindly tell me the solution if you found.
