Fiber access down?
Hello,
My fiber connection just went down, I don’t really have any logs to provide from my Netgear router.
Do we have any information about an outage somewhere (Haute‑Vienne for me)?
Nothing visible here: https://status.isp.ovhcloud.com/
I’m trying to investigate at home, or is it an OVH‑side problem?
PS: no "telecom/internet" tag available to create the topic :slight_smile:
@FabL do you have any info on your side?
[EDIT]
Ticket # CS15714563; even though I think the problem is widespread. The time of my outage lines up exactly with the generic incident detected in the 33, and I see generic incidents are being reported on status.isp.
[/EDIT]
Hello @Sich,
There is an ongoing incident on the network side, but it’s being resolved.
There is no open work task; if this differs from what you’re currently experiencing, I invite you to keep your ticket open.
^FabL
yep it’s already back up, a little under an hour of downtime!
Thanks for your feedback :slight_smile:
