Can't use remote-ssh extention of vscode in my shared web hosting plan (Pro)
Hello everyone,
I use the Pro offer :
I have the following problem / I would like to set up :
I've been trying to connect to my ssh using the VS Code extention "Remote SSH", I edited the config file just like i've done it previously but this time, it doesn't work.
this is the error i'm getting:
!pb20240228|551x280
error code in visual studio code]
and this is what the console looks like:
![pb20240228_2|690x197
[console logs]
it says in the last line that i should change AllowTcpForwarding in sshd_config but i don't have access to that (i don't think) when using a shared web hoster like OVH.
i wonder if it's even doable to have access to my files via this VS code extention or i should just give it up?
please note that the ssh connexion via terminal does work. it's with the VS code extention that i'm having this issue.
i have tried adding 'AllowTcpForwarding yes' to the config file, tried to access the sshd_config file from console but it didn't work because of permissions.
i have also tried deleting .vscode-server folder and connecting again.
Hi! I have a the same issue.
Do you have any update?
Can the user support mind the customers ?
