la commande docker fonctionne
bravo l'expert
le user était ubuntu
merci 1000 fois
voici les commandes que j'ai passé
root@vps-a71e1ee4:/# passwd
New password:
Retype new password:
passwd: password updated successfully
root@vps-a71e1ee4:/# ls /home
thread 'main' (1196) panicked at /build/rust-coreutils-u5JpDp/rust-coreutils-0.8.0/rust-vendor/rustix/src/backend/linux_raw/param/auxv.rs:269:22:
called Result::unwrap() on an Err value: ()
note: run with RUST_BACKTRACE=1 environment variable to display a backtrace
Aborted ls --color=auto /home
root@vps-a71e1ee4:/# echo 'debian:xxxxxx' | chpasswd
chpasswd: (user debian) pam_chauthtok() failed, error:
Authentication token manipulation error
chpasswd: (line 1, user debian) password not changed
root@vps-a71e1ee4:/# echo 'ubuntu:xxxxxxx' | chpasswd
root@vps-a71e1ee4:/# exit
exit
[RESCUE] root@vps-a71e1ee4:~ $ umount /mnt/sdb1
PS C:\Users\Proprietaire>
PS C:\Users\Proprietaire> ssh ubuntu@92.222.67.200
ubuntu@92.222.67.200's password:
Welcome to Ubuntu 26.04 LTS (GNU/Linux 7.0.0-31-generic x86_64)
System information as of Mon Sep 14 13:03:32 UTC 2026
System load: 0.08
Usage of /: 89.1% of 37.65GB
Memory usage: 15%
Swap usage: 0%
Processes: 142
Users logged in: 0
IPv4 address for ens3: 92.222.67.200
IPv6 address for ens3: 2001:41d0:404:200::2d5d
=> / is using 89.1% of 37.65GB
Canonical Workshop gives developers fast, composable, reproducible, and
secure developer environments that are perfect for agentic workflows.
https://ubuntu.com/workshop
Expanded Security Maintenance for Applications is not enabled.
16 updates can be applied immediately.
To see these additional updates run: apt list --upgradable
Enable ESM Apps to receive additional future security updates.
See https://ubuntu.com/esm or run: sudo pro status
Last login: Wed Aug 26 04:55:16 2026 from 89.92.31.187
ubuntu@vps-a71e1ee4:~$
System load: 0.08
Memory usage: 15%
Swap usage: 0%
Processes: 142
Users logged in: 0
ubuntu@vps-a71e1ee4:~$ docker --version
Docker version 29.7.2, build a7dcaa6
