Bonjour, je n'arrive plus a ouvrir mon site vous pouvez m'aider svp ??
Ci dessous le message qui s'affiche !!
Can’t select database
We were able to connect to the database server (which means your username and password is okay) but not able to select the caribao004 database.
Are you sure it exists?
Does the user caribao004 have permission to use the caribao004 database?
On some systems the name of your database is prefixed with your username, so it would be like username_caribao004. Could that be the problem?
If you don’t know how to set up a database you should contact your host. If all else fails you may find help at the WordPress Support Forums.
Analysez votre fichier wp-config.php et comparez les identifiants de votre base de données avec ce qui est inscrit dans la config PHP:
server name
database name
user
password
