Impossible d’envoyer des mails vers gmail bis
Bonjour,<br />Je rencontre visiblement le même type de problème que Gabrielle avec mon nom de domaine chez OVH et mon site chez Wix, mais je ne parviens pas à trouver la solution malgré tous les conseils envoyés ici... Serait-il possible de me donner un petit coup de main svp ? <br />Voici le message d&#39;erreur quand j&#39;essaye d&#39;envoyer un message vers Gmail :<br />This is the mail system at host mo559.mail-out.ovh.net.<br /><br />I&#39;m sorry to have to inform you that your message could not<br />be delivered to one or more recipients. It&#39;s attached below.<br /><br />For further assistance, please send mail to postmaster.<br /><br />If you do so, please include this problem report. You can<br />delete your own text from the attached returned message.<br /><br />                   The mail system<br /><br />gmail.com&gt;: host gmail-smtp-in.l.google.com[173.194.222.26]<br />    said: 550-5.7.26 This mail has been blocked because the sender is<br />    unauthenticated. 550-5.7.26 Gmail requires all senders to authenticate with<br />    either SPF or DKIM. 550-5.7.26  550-5.7.26  Authentication results:<br />    550-5.7.26  DKIM &#61; did not pass 550-5.7.26  SPF [dfci.pro] with ip:<br />    [178.32.123.152] &#61; did not pass 550-5.7.26  550-5.7.26  For instructions on<br />    setting up authentication, go to 550 5.7.26<br />    https://support.google.com/mail/answer/81126#authentication<br />    u6-20020a05651220c600b005114f50fc90si399115lfr.342 - gsmtp (in reply to end<br />    of DATA command)<br />Reporting-MTA: dns; mo559.mail-out.ovh.net<br />X-Postfix-Queue-ID: E9B6428529<br />X-Postfix-Sender: rfc822; contact@dfci.pro<br />Arrival-Date: Tue,  6 Feb 2024 07:52:15 &#43;0000 (UTC)<br /><br />Final-Recipient: rfc822; m.entressangle@gmail.com<br />Original-Recipient: rfc822;m.entressangle@gmail.com<br />Action: failed<br />Status: 5.7.26<br />Remote-MTA: dns; gmail-smtp-in.l.google.com<br />Diagnostic-Code: smtp; 550-5.7.26 This mail has been blocked because the sender<br />    is unauthenticated. 550-5.7.26 Gmail requires all senders to authenticate<br />    with either SPF or DKIM. 550-5.7.26  550-5.7.26  Authentication results:<br />    550-5.7.26  DKIM &#61; did not pass 550-5.7.26  SPF [dfci.pro] with ip:<br />    [178.32.123.152] &#61; did not pass 550-5.7.26  550-5.7.26  For instructions on<br />    setting up authentication, go to 550 5.7.26<br />    https://support.google.com/mail/answer/81126#authentication<br />    u6-20020a05651220c600b005114f50fc90si399115lfr.342 - gsmtp<br /><br />Un grand merci !
dfci.pro
Pas de SPF configuré chez Wix.
https://blog.demees.net/cname-ovh-systemeio-shopify-heroku-odoo-wix-monsite/
Parfait, merci beaucoup pour le guide, ça fonctionne !
