I can’t get my first page online
Good evening, I'm stuck at the password step – I’m using a copy‑paste of the Astérix FTP credentials and I think it’s the part before the username. I’m pretty sure it’s correct; if I change the password it works, but then a panel shows an error. Maybe it’s not effective yet since I just purchased it. I haven’t had my address for very long. If anyone can help, I’d appreciate it. Thanks in advance.
Good morning @ea620692-ovh
Take a look at this documentation:
https://docs.ovhcloud.com/es/guides/web-cloud/web-hosting/web-hosting-getting-started/
If you have any further issues, let us know.
Regards,
Sergio Turpín
Bonjour @ea620692-ovh
Could you give us more details:
  • Which domain?
  • Which CMS (WordPress, Joomla, Spip, etc.)
  • Installation performed by OVH at the time of purchasing the hosting or "one‑click"?
  • Installation done by you?
If it is a WordPress "one‑click" installation, the cleanest approach is to uninstall everything and install WordPress manually and properly.
See in my guide the paragraph: X5 - Suppression d’un site installé « en un clic »
Here is a short guide I wrote that could give you clarification for a Complete and clean Installation of your Site.
Guide - Understanding the Relationship Domain > DNS Zone > Hosting > Site Folder
See --> CMS - WordPress - Guide Installation chez OVH
Read and check your situation by following carefully the paragraphs: A to J valid for all CMS
Feel free to give me feedback: positive or negative.
That’s how I fine‑tune my guide.
Hello, thank you for your response
My site
QuelquepartenProvence.fr
With OVH hosting, free, 100 MB
I use Readdle to upload the site
OVH created me an FTP username and password, and when I enter them each time it shows an "invalid username or password" error. When I try to modify it, it approves the first time, then shows a yellow panel saying "invalid password" error. I just want to put a first page on my site to see how it works, but I can't manage it. You understand, I’m doing everything myself but I’m not a professional; it’s just a personal site I want to create. Thanks for your help.
Hello @ea620692-ovh
FTP password:
16 characters in random order – numbers, letters, uppercase, lowercase – No accented or exotic characters
Excerpt from my guide:
https://www.wordetweb.com/word-et-web/Telechargements/infos_Profil.txt
Hello @ea620692-ovh
https://quelquepartenprovence.fr --> Site under construction
Via FileZilla replace index.html with index_ovh.html
And place your /www/index.php file there.
