Hello all,
I have an OVH VPS running Ubuntu 20.04. I tried to configure my LXD containers to use a public IPV4 failover /32. Unfortunately, I only managed to make it work on LXD containers running Ubuntu 16.04 (using ifupdown for network configuration) but NOT on LXD containers running Ubuntu 20.04 (using netplan).
A bridge device br0 is configured on my VPS with public IP HOST_IP. I have two additional IPs provided by OVH: OVH_FAILOVER_IP1 and OVH_FAILOVER_IP2.
I have configured two LXD profiles, and both containers c1 and c2 use both of them:
- “default”:
config: {}
description: Default LXD profile
devices:
eth0:
nictype: bridged
parent: lxdbr0
type: nic
root:
path: /
pool: default
type: disk
used_by:
/1.0/instances/c1
/1.0/instances/c2
- “extbridge”:
config: {}
description: Lets containers use public network interface
devices:
eth0:
nictype: bridged
parent: br0
type: nic
used_by:
/1.0/instances/c1
/1.0/instances/c2
This is the output of “lxc network list”:
| NAME | TYPE | MANAGED | DESCRIPTION | USED BY |
| br0 | bridge | NO | | 3 |
| ens3 | physical | NO | | 0 |
| lxcbr0 | bridge | NO | | 0 |
| lxdbr0 | bridge | YES | | 1 |
In container c1, I have the following configuration (inspired by this blog: https://thomas-leister.de/en/lxd-use-public-interface/):
- in /etc/network/interfaces:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
auto eth0
# iface eth0 inet dhcp
iface eth0 inet static
address OVH_FAILOVER_IP1/32
gateway GATEWAY_IP
dns-nameservers DNS_IP
source /etc/network/interfaces.d/*.cfg
# NOTE: directory /etc/network/interfaces.d/ is empty
- in /etc/resolv.conf:
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND – YOUR CHANGES WILL BE OVERWRITTEN
nameserver DNS_IP
In container c2, I have the following configuration:
- in /etc/netplan/10-lxc.yaml:
network:
version: 2
renderer: networkd
ethernets:
eth0:
dhcp4: no
dhcp6: no
addresses:
- OVH_FAILOVER_IP2/32
gateway4: GATEWAY_IP
nameservers:
addresses:
- DNS_IP
# 127.0.0.53 is the systemd-resolved stub resolver.
# run "systemd-resolve --status" to see details about the actual nameservers.
nameserver DNS_IP
nameserver 127.0.0.53
The output of “lxc list” is:
| NAME | STATE | IPV4 | IPV6 | TYPE | SNAPSHOTS |
| c1 | RUNNING | OVH_FAILOVER_IP1 (eth0)| | CONTAINER | 0 |
| c2 | RUNNING | OVH_FAILOVER_IP2 (eth0)| | CONTAINER | 0 |
Container c1 works correctly: from within the container I can ping the internet (e.g., “ping -c 4 …”) and I can also netcat the container from the host and from outside (e.g., “netcat -l 80” on the container and “netcat OVH_FAILOVER_IP1 80” on the host or outside).
Container c2 does not work: from within the container I cannot ping the internet (“Network unreachable”) and the container is not accessible from neither the host nor outside.
I am a bit confused: it seems to me that the two configurations are the same (except one uses ifupdown and the other uses netplan, but the result should be the same?).
One thing I have noticed is that in container c1, the command “ip addr” gives something like:
eth0@if45: mtu 1500 qdisc noqueue state UP group default qlen 1000
inet OVH_FAILOVER_IP1/32 brd OVH_FAILOVER_IP1 scope global eth0
while in container c2 it gives:
eth0@if47: mtu 1500 qdisc noqueue state UP group default qlen 1000
inet 54.38.226.92/32 scope global eth0
I am not sure if broadcasting is relevant here…
Another difference is the output of “networkctl”:
in c1:
WARNING: systemd-networkd is not running, output will be incomplete.
IDX LINK TYPE OPERATIONAL SETUP
1 lo loopback n/a unmanaged
44 eth0 ether n/a unmanaged
in c2:
1 lo loopback carrier unmanaged
46 eth0 ether routable failed
Do you have any clue of what may cause the difference in behaviour?
I have posted the same issue on the Linux Container Forum: https://discuss.linuxcontainers.org/t/network-unreachable-in-lxd-container-configured-to-use-ovh-failover-ip-with-netplan/9848/5
One contributor suggested that this may be due to OVH enforcing that all external IPs use the same MAC address for VPS (actually it seems not possible to add a virtual MAC address on failover IPs associated to a VPS). Based on the OVH documentation, I think this may be true (enven though I was unable to find it explicitly written). But what is surprising is that one of the container (c1) actually works.
Thanks a lot
