Hello,
We are encountering intermittent errors on Object Storage S3 in Paris and are trying to determine whether we are hitting a limit, a client setting, or a best‑practice issue. A ticket has already been opened with OVHcloud support; I am also posting here to gather your experience.
Context
- Region:
eu-west-par. - Endpoint:
https://s3.eu-west-par.io.cloud.ovh.net. - Private bucket, about 267 000 objects referenced by our application, mainly immutable 4 MiB blocks with keys based on a hash. This application inventory is not an exhaustive listing of the bucket and its versions.
- Our application uses the AWS SDK for Rust for PUT/GET, with full data verification after each upload. We have also reproduced the errors with curl, outside the application, via presigned URLs.
- These blocks are used for synchronization and on‑demand reads of virtual disks: a delayed or failed read can block synchronization or execution.
Actually observed error
<Code>ServiceUnavailable</Code>
<Message>Service is unable to handle request.</Message>
HTTP status 503. The captured responses contain ServiceUnavailable, not SlowDown.
Reproduction on 7 October 2026 — UTC times
- Between 09:49:59 and 09:50:02: the same existing object was read three times from each of the following paths: workstation Internet connection, production server, and application container. Result: 3 503 errors out of 9 requests, with successes and failures on the same object. Each path experienced at least one failure.
- Between 09:53:53 and 09:54:23: four nearby keys, from the workstation and the server, with full GETs over IPv4 and
Range: bytes=0-0GETs over IPv6. Result: 7 503 errors out of 16 requests. Even a one‑byte read could fail. - Between 09:55:41 and 09:56:12: four distant hash prefixes (
0,4,8,c). Result: 2 503 errors out of 16 requests. - Between 09:56:57 and 09:57:18: three rounds of one‑byte GETs over IPv4, interleaved across those four prefixes. Result: 12 successes out of 12, with time to first byte ranging from 0.30 to 4.23 seconds.
These are small, selected samples, not an estimate of the overall error rate. The IP address and GET type varied together in some runs; therefore we do not infer that IPv4, IPv6, Range requests, or a particular prefix are the cause.
Some request IDs for possible correlation on the OVHcloud side:
- 09:49:59.425 UTC:
tx346a993e11064976a1743-006ac615c6. - 09:50:00.895 UTC:
tx7e1bdbc1cb8843e0a9b27-006ac615c8. - 09:50:01.167 UTC:
txe342465496d2475494555-006ac615c8. - 09:54:11.301 UTC, one‑byte GET over IPv6:
tx3beed3597e3041b387bd5-006ac616c1.
Throughput and checks already performed
During a roughly 36‑minute window, the SDK's application counters averaged 0.81 GET/s, 0.82 PUT/s, and 1.98 purge operations/s. These counters do not necessarily include all HTTP retries, and a purge can call multiple APIs: therefore they are not a measurement of peaks nor a complete audit of bucket traffic. Our current application limits are four simultaneous uploads and eight simultaneous reads.
The documentation of the S3 limits states soft limits of 900 GET/s and 300 PUT/s in European regions. The available measurements do not show us approaching those values; however we have not ruled out an account‑specific limit or a brief spike.
- The XML 503 errors were reproduced from two independent Internet connections, with curl and no SDK.
- The same objects succeed on other attempts: it is not a permanent signature or permission failure.
- The keys contain hashes; we do not use a monotonically increasing timestamp prefix.
- The server’s physical disks were not saturated during the measurements. The server had real CPU activity, but that alone does not explain the same S3 503 response from the workstation.
- The public status page did not report a corresponding incident when we checked.
What we are trying to understand
- Have you ever encountered this
503 ServiceUnavailableon existing objects, at low throughput, ineu-west-par? - Can shard redistribution or versioning/purge activity cause these GET errors even far from the advertised limits? Are there metrics to confirm this? We have read the sharding and performance documentation, but cannot attribute the incident to that mechanism.
- Is there an endpoint, a storage class, a bucket/account‑specific limit, or an SDK/HTTP setting that should be checked first?
- What additional tests would help distinguish a connection/keep‑alive issue, throttling, a problematic shard, or a service incident?
- What concurrency, timeout, and retry‑with‑backoff/jitter values do you recommend for immutable 4 MiB blocks with on‑demand reads?
We first want to understand and fix the problem. If this instability continues, we will have to migrate the data to another provider, as read reliability directly impacts the recovery of our disks.
Thank you for any pointers; we can provide additional anonymized logs and pass bucket‑specific information directly to support.
